Question about Toshiba TW40F80 40" Rear Projection Television
Tw40f80 with blinking power light
My tw40f80 goes into protection mode as soon as the HV supply tries to come on, i hear the high frequency the flyback generates and about a half second later it clicks into protection mode and the power light blinks, do you know of a reputable place to obtain the service manual which will have the circuit diagram for the power supply sections of this TV?
I replaced both convergence IC's and their large low ohm resistors already thinking that they had gone bad, but still having the same results, none of the fuses in the power supply section are blown, already removed them and tested with a multimeter, they all check out fine.
-Garret
I HAVE SERVICE MANUAL FOR TW40F80
ELCIDY@HOTMAIL.COM
Posted on May 20, 2009
How do you test a 1kvolt ceramic capacitor?
Hi Mixers,
You can test a 1kvolt ceramic capacitor;
a) using a capacimetre; replacing with other one of the same type; connecting it in a 12V oscillator circuit with a LED as output wich shall blink in a frequency determined by the capacitance, says, fast with low capacitance and slow with high capacitance. Normally ceramic HV capacitors are of small capacitance for use in high switching circuits or as a protection of a power switching transistors in modern power supplies
Feb 13, 2012 | Food Mixers
Mitsubishi WS-55511 - No Power - No Blinking Light
This can be a problem with the powersupply of the television that's why you hear a high frequency noise and there's no power or any light coming on , the power supply may gone bad and needs replacement..
Good luck.......
Aug 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No power on (LCD27TV006HD)
Does the standby light continue to blink? IF so, count the number of blinks and go to:
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
That may help you decide what is going on.
In the long run you will probably need to have a tech take a look at it. The problem you describe is usually a serious matter that needs repair by a trained technician..
Goodluck,
Don't forget to rate me as fixya...
Feb 03, 2008 | Televison & Video
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
My sony trinitron will NOT turn ON, and blinking standby light is constantly blinking... what is the common problem with this?
If you let us know how many times the light blinks, that will let us know whereabouts the fault area lies. Her is the list. I hope it is helpfull.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
Jan 19, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have a sony Trinitron kv-32fs17 and i left ON while I was working around the house. The screen went OFF by itself. I tried to turn it back ON and all I got is this red light flashing. I unplugged the...
The flashing led will give the engineer a clue as to where the fault may lie.
The most common number of flashes is ... well here's a list.
Hope it helps.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Nov 14, 2010 | Televison & Video
Is the t603 and r672 part of the tv or the actual circuit breaker
Three blinks - B over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
DOES THIS ABOVE issue have anything to do with Cooling FAN?
I cannot hear the cooling fan come on when first turned on like
before THANKS
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
change......
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
No powering up
2 blinks is +B OCP protection. The manual states "Short circuit of power supply system in each circuit." and "Goes to the standby mode. Short circuit of +B line"
Dec 10, 2007 | Sony KP-53XBR200 53" Rear Projection...
Sony Big Screen TV Not Powering On
This looks like a problem with the High Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
Aug 15, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
164 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
