Question about Emerson Fans Emerson MW8115SS Microwave Oven
Model mw8115ss suffix a Emerson Microwave not working
My Emerson Microwave truntable is not working and not heating the food. It is getting power and the digital counter works for differnt power use. Pls help
  • 3 more comments
  • seifuhm Aug 04, 2008
    Yes, the inside light comes on but turntable stay
    still no rotation, no noise at all. Everything is just dead except the inside light is on when try to cook.
    Digital function works perfect when you push any cooking level/instruction.
    TKS
  • Anonymous Jan 12, 2009
    YES
  • tanya01902 Jan 18, 2009
    heat is not working turn table not moving red symbols flashing under timer
  • Anonymous Feb 12, 2009
    Aloha,
    I went to fixya and don't see a way to fix this door problem. How do I check the doors continuity? And, could it be something else? I don' want to do all this and it turns out to be something esle. Would it be cheaper and time saving to buy a new one.
  • William Miller
    William Miller May 11, 2010
    Do the inside light and turntable come on when you try to cook?
    Is it making any unusual noise or is it louder or quieter than normal?
  • Emerson Fans Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Posted on Aug 05, 2008
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Emerson model mw8115 ss
The problem is caused by one or two bad door switches that will need to be replaced.
Mar 14, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Microwave stopped working during heating process....timier works but does not make that microwave sound
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | Emerson Fans Emerson MW8115SS Microwave...
Mw1161sb suffix a emerson microwave not heating food
Basic
heatman101
[]\\\\\\\\\\\\\\0
Dec 18, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
I just purchased an Emerson 1000W Microwave, Model #MW8115SS. I took out of box, removed the blue covering that protects the finish and when I plugged in and turned it on to heat something up, it was very,...
The unit may be more powerful than your last one. if its probably is normal 1100 w is a lot of power. if it works well and you in joy it, then you will soon be used to the new sound of power Good luck DFD
Apr 13, 2009 | Emerson MW8108P Microwave Oven
Please i have looked everywhere::::: i need a hv capacitor for emerson mw8115ss suffix b. info on capacitor is: ch85-21090-2100V-AC 0.90uf+-3%b 10/85/21 50/60Hz No PCB's V000480 Made in Ningbo China
p/n MOS0857 on sears com.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MW8102SS&productCategoryId=0123245&brandId=0352&modelName=MICROWAVE&diagramPageId=00001&componentDescription=CABINET%20PARTS&documentId=50020101&backToLink=Return%20to%20Sub%20Components%20list
Jan 25, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Mw8115ss
The controler board may not be outputing to the relay or thyristor (depending on the device used) for the magnetron power supply, or the magnetron may have failed, or the high voltage supply may have failed. This is just to mention a few things that can cause the nature of the fault condition that your microwave oven has.
You will have to take the oven in for an estimate. You may find it cheaper to replace it if it is not under warranty.
Jerry G.
Apr 18, 2008 | Emerson MW8985W Microwave Oven
Emerson mw8115ss microwave
If you don't have your manual, you can download it here:
http://emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
The manual will also have contact info for Emerson in case you want to check with them on this.
The magnetron may be going bad, and they usually have a warranty of several years on that.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
Emerson Fans Emerson MW8115SS Microwave Oven Logo
1,203 people viewed this question
Top Emerson Fans Microwave Ovens Experts
William Miller
William Miller
Are you an Emerson Fans Microwave Oven Expert? Answer questions, earn points and help others
