Question about Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White
We purchased the fridge in Jan a '11, today the freezer was not as cold as it should have been to the point the ice cream was soft. According to the manual, I increased the temp from 4 to 5. Since then the fan has not stopped running. Is it running because it is changing temp and if so, how long will it run for? Thank you
    Guru:
  • 1,524 Answers
The fan should run cotinously until either the temperature is satisfied or the unit goes into defrost.
Changing from 4 to 5 is not a way to determine the temperature, rather you should use a good thermometer. Look for 0*F.-5*F.
Posted on Mar 24, 2011
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Kitchen Aid bottom freezer KBRS22KK is frosting up
Replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Dec 01, 2012 | KitchenAid KBRP20EMSS Bottom Freezer...
Model TFH30PRTA NOT KEEPING ICE CREAM FROZEN
Ice cream will get hard when the temperature is closer to - 20 C or -1 F scale. Water becomes Ice at 0 C or 32 F scale.
Ice cream soft means your freezer is not cooling enough.
You were cleaning the coils? Both condenser and evaporator coils? Cleaning coils and then loosing cooling in the fridge is not a good sign or combination. May be there is a freon leak and the seal system is low on freon now.
Call a service tech to check the seal system.
Unfortunately, if it is a leak you may eventually buy a new fridge after spending money on freon fill up, freon system sealant, leak check etc etc... No good news. Sorry
Oct 25, 2017 | GE Profile Performance 29.8 cu. ft....
Ice Cream In Freezer Is Soft
DON'T BY ICE CREAM! LOL Try putting ur ice cream somewere else
Oct 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana BR18 fridge/freezer. Fridge is cool but not cold, freezer is at about 20 degrees. Ice cubes are frozen but ice cream is soft. Any ideas?
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
Oct 04, 2009 | Freezers
Hotpoint 14.2 cu ft top freezer refrigerator -- at least once a day, according to repair company, the "heater" comes on in the freezer to defrost unit. At that point the temperature in the freezer slowly...
well for one thing i have never of a home frige unit have a heater unit on it all stores have a heater unit around the doors so the door opens easily current fridges work on a simple fan cycle the movement of the air from the freezer goes down the fridge to keep things cold and the food in the frezer frozen all this is controlled buy venting of the air from the freezer you open and close the vent to direct the cold air flow from on top to the bottem for coldness and that s all it does. i would call the better business bearu and check there standing s or a second opinion and you gathere the information good luck
Aug 10, 2009 | Hotpoint HTR16ABSR Top Freezer...
Ice cream soft
Ice Cream is the hardest thing to freeze in a fridge /freezer unit , you need a least 0 deg F
to harden ice cream. If the ice cream was satisfactory before the repair and the stat is set to max. it is possible you have an over charger refrigeration circuit.
Fuji
Aug 06, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer and fridge not getting cold
you have a sealed system leak or possible restriction in system. need to check freon pressure. make sure compressor is running. if not ohm out start device
Jun 21, 2009 | GE GSH22JFR Side by Side Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Gets only cool not cold
Vanilla Bean Ice Cream
makes 1 generous quart
4 egg yolks
2/3 cup sugar
2 cups half-and-half
1 vanilla bean or 2 teaspoons vanilla extract
1 cup whipping cream
In a bowl, beat the egg yolks until blended and mix in sugar. Heat the half and half, stir into the egg yolks, and pour into the top part of a double boiler. Split the vanilla bean and scrape its seeds into the cream and add the bean as well. Place over simmering water and stirring constantly, cook until the mixture is custard-like and coats the spoon. Remove from heat and refrigerate until cold, or several hours. Remove vanilla bean. If using vanilla extract, stir it in at this point. Just before ready to churn; stir in the whipping cream. Freeze according to directions for your ice cream freezer.
Sep 03, 2007 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Whirlpool 24.8 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - White-on-White Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
