Question about Vacuums
Broken belt I have a royal canister model 4750 with a broken belt on the power head. I don't know how to disassemble the head to get at the belt.
  • mfolske Aug 06, 2008
    Great! Thank you.
    Novelist:
  • 97 Answers
If you have the power head with the headlight, squeeze the sides of the upper part (almost like a superstructure,) where the headlight is located. It should lift off, allowing access to the screws to get the powerhead apart the rest of the way, and on most models it even has instructions on how to replace the belt molded into the plastic.
-R
Posted on Aug 04, 2008
Why is my power head not working
You either have a broken power cable going to the head or your canister isn't supplying power to the head, or the motor for the head it bad.
Dec 13, 2015 | Shark Professional Canister Vac - EP754 -...
Power head is spraying out dust. No particles are going into the water
You can check the belt. If you rainbow belt is broken the power head will seem to spit dirt back out.
May 15, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Hoover bagless cannister 3765 - belt on power head slips off spindle. bought new belts - same problem. is this a design problem or can it be fixed? I don't want to take it to a repair shop 100 miles...
I would not recommend a smaller belt. You will only wear the motor. This model series power nozzle needs to have a metal clip installed near the belt on the brush roller housing. I know that most of them left the factory without it. Remove the cover to see if one is ther. if not have your dealer send you a clip or a housing with one on it.
Apr 03, 2010 | Hoover S3765-040 WindTunnel Bagless...
I have an Electolux Oxygen canister vacuum and the power head suddenly stopped working. It is only a few months old. Any suggestions.
1. You have to verify if it's simply the belt that has broken and the spinning brush isn't spinning because of it. Place your ear next to the top of the power head to listen for the power head motor. If electricity is getting to the head you'll hear the motor and know to inspect the belt.
2. If the motor doesn't run, look at the electrical pin connectioins in the pipe from the hose to the head. Are they burnt? If yes a new wand is needed. Also check the electrical connections in the hose handle and make sure they are not burnt.
Let me know if this helps
Oct 09, 2009 | Electrolux Oxygen Z5540 Pet Lover Vacuum
Royal 3050 power head does not run
The sounds like powerhead motor either burned up, or the belt broke and got tangled in the turning motor shaft. Pull the bottom off the power head and look for a curled up rubber band. If you find one, it's the belt.
If it's the motor, you won't hear it running when you turn the powerhead on.
Jan 23, 2009 | Royal Procision 3050 Bagged Canister...
Broken belt in Royal Pony power head
We have a Royal Pony as well. Here is their general help desk number. Just call them and give them the model number of  you tank. it's on the bottom of your machine. 1.800.321.1134
Nov 25, 2008 | Vacuums
Broken power head belt
Not sure which one you have, need complete model number. You can go tosears.com, click on the parts link, enter you model number, click on the powerehead link. A parts list will come up along with a picture breakdown of it.
Alot of them the part covering the light is just snapped into place, push in on the side andback to release it. Remove the 2 screws, use a flatblade and stick in the slot on each side from the bottom and pry up to release it.
The other type, you tak out the 2 screws from the bottom, then on the back and each side are release tabs that you pry out to release.
May 08, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Euro-Pro head cranky
The air driven head is probably bond up and needs to be cleaned. Alot of the air driven ones have a belt that may be broken or stretched.
Jan 10, 2008 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Vacuums Logo
114 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
