Https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
See link above:
I always post a link to a great repair help and parts supplier
It will also show disassembly and diagnostic help topics.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
SOURCE: Pump in tank wouldn't turn on
Sounds like you've already figured ti out. The pumps on these fail regularly. I would bet youve got a bad one. If you want to know for sure, check for 110 volts across the two wires at the pump when it is running and supposed to be draining. If voltage is there, but no pump run, order a pump and you'll be back in buisness. Good luck!
SOURCE: Wher to buy eurotech EWC177W
Poor Earth Grounding
One of the biggest problems with electric gates is poor installation. In particular, many people do not properly ground the gate or fence during installation. Grounding rods must be placed under the gate in order to keep it safe for people and animals. Drier climates require more grounding rods. An improperly ground gate can cost thousands of dollars to repair.
Barbed Wire Fencing
Some farmers have tried to electrify a barbed wire fence, but this is a major safety hazard to animals. Animals can get stuck in barbs whether or not they are electrified, but the added electricity can lead to their death. Barbed wire should be avoided on farms and should never be electrified.
Interference
Occasionally, electric gates may experience technical difficulties due to interference. Local radio, television, or telephone signals or wires can cause the interference for both the media system and the gating system. Such interference can cause the gate to lose its electric charge temporarily. The interference can also cause brief spikes in electricity in the gate, which can be a safety hazard to people or animals.
Insufficient Animal Training
Since electric gates on farms are intended to keep animals in their assigned area, the animals must learn about the consequences of crossing the electric gate. Farmers or property owners must therefore train their animals to avoid the gates. To train the animals, owners must actually expose them to the electric shock. Owners who fail to shock-train their animals may find that their animals become obstinate or may get seriously injured.
Crime Target
Owners who install electric gates at the edge of their property often do so for security. Ironically, the presence of such high-tech gates may signal to would-be robbers that the owners are very rich, making the owners theft targets. Property owners may want to install an alarm system to accompany the electric gate to increase security.
SOURCE: EuroTech 158 Dryer. Green Light
Hi If everything is cleaned then all you have to do is turn
on the machine, turn the knob to STOP, and wait a couple of seconds. You'll
hear a tone and the light will stop blinking. If the issue returns and
the drain filter inside the lower front assembly are cleaned then the issue is
with the pump relay on the control board that is bad and should be replaced. Hope
this helps...please post back for further assistance. Daniel
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
