Question about Whirlpool GS6NBEXR Side by Side Refrigerator
I have a gs6nbexrs01 refrigerator. The origanal problem was that the ice dispensor door would not open when selected. I removed the dispensor unit inorder to check to see if there was an obstruction to the motor. I cleaned up the door area and motor area but found just dirt and some mold. I reassembled the unit and installed it but now I have no power to the dispensor unit--no light, water etc. Is there a reset switch or fuse for the unit?? If not what is my next step??
    Champion:
  • 239 Answers
I suspect you have some broken wires in the wire bundle that feeds the dispenser system in the door. Look behind the kickplate ate the bottom hinge for the freezer door. There is a black mesh covering the wires to the dispenser components. Unplug the refrigerator and see if the wires are broken inside that mesh.
Kelly
Posted on Mar 24, 2011
Ice through trap door
To prevent this problem of ice formation, you need to maintain a fix time interval of switching on and off your refrigerator unit. It will help in maintaining cooling as well as ice level.
Jan 02, 2014 | LG LFX25960ST Stainless Steel French Door...
How to open ice/water dispenser on GE PSS26LSRDSS to replace ice door flap
TAKE SMALL SCREWDRIVER AND GENTLY PRY OFF DISPENSOR COVER, THEN UNPLUG 3 SETS OF WIRES FROM BOARD. THEN REMOVE 4 SCREWS HOLDING ON THE DOOR ACTIVATOR. DOOR RECESS THEN CAN BE REMOVED AND REPLACED.
EITHER UNPLUG UNIT OR OPEN FREEZER DOOR TO PREVENT ELECTRICAL SHOCK.IF OPENING DOOR KEEP DOOR OPEN WILL KILL POWER TO THE BOARD AREA.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Jan 17, 2013 | GE Refrigerators
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Ice dispenser delivers only crushed ice.
Make sure the dispensor door flap is closing completely .
Remove the ice bin , close the door , set the display for cubed and press the dispensor pad . Do you hear a " clunk " sound ? If not , open the door and press on the light switch , and activate the pad again . On the back wall , next to the " forks " , is a square hole with a white plastic square . Does this plastic square raise up ? If not , remove the top freezer door hinge cover and disconnect the plug there ( this removes power to the dispensor ) , you will have to remove the 4 screws holding this panel , and determine if the solenoid is bad , wire came off , or plastic piece is broken . If the plastic piece does lift , then the problem is in the ice bin . Lift the long rod , and see if the flap moves , where the ice comes out . If not , you will have to determine why .
Nov 03, 2009 | GE GSH22JFT Side by Side Refrigerator
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice chute door hangs open ...kenmore 106.57904700
Access from front of freezer door. Trim is just pushed into friction holders. Selector area snaps in. Phillip screws under that removes ice shoot.
Sep 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker door stays open. How do I take off front panel to revel parts?
Remove the top freezer door hinge cover and disconnect the plug there . This removes power to the door only . Between the dispensor grate and the dispensor cover , inside at the bottom inside dispensor , insert a butter knife and push down and inward , to pop the bottom of dispensor cover outward , on each inner side . This will pop the 2 plastic clips on the cover off . Lift the cover , to pass the plastic retainer tabs . Disconnect the plug to the dispensor . There are 2 screws holding the white housing which has the switches mounted onto it . Remove these screws , and slide the housing foreward and lift . You should be able to see the complete flap door and the spring and pin , to decide what is causing the door to stay open . If you come back with the found problem , and the model number , I would be able to give you the part number(s) needed .
Sep 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Bin Dispensor freezes
you might try asking the mfg. site about this problem
https://jennair.com/appliances/details/JS42SSDUDE
did a search and nothing else come up. give them a try.
Dec 02, 2017 | Jenn-Air JSD2690HES Stainless Steel Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
159 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
