Bosch washer wfmc330suc still wont drain after pump replacement
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Check all hoses clear including the sump hose ..if this has non return BALL fitted remove it.Check wiring to ensure voltage present at the pump, you wil need a multimeter to do this one...Good luck
Posted on Mar 24, 2011
I have a Bosch WFMC330SUC that does not end the cycle, it just keeps starting over. I assume it is a bad control board, but they are $300+ and I'd probably replace the machine instead. Any suggestions?
Hi wwwylie,
First check the Drain Pump filter, as the last 2 cycles of a machine is Drain & Spin, and if the Drain pump cannot drain the water, the filter may be clogged and the cycle won't progress to spin.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 16, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My bosche mod # wfmc1001uc wont spin with clothes in it.
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My little boy put my bosch exxcel washer/dryer on to dry for 2hours and then switched it to drain and then turned it off, now its stuck halfway through drain and the door wont open.
i have never worked on this type of washer dryer combo, but just from experience if a washer will not unlock and it keeps trying to drain it is either there is enough water in the unit to trip the pressure switch and the pump keeps trying to drain, means there is a blockage normally in the pump, blocking the pump, or blocking the pressure switch tube. clean these out and unit should work fine. if you arnt tech savvy , call a professional and be prepared to pay.
Nov 24, 2010 | Bosch Washing Machines
My bosh frontload washer wont spin or drain
If it does not drain, then it will not spin.
Locate and clean pump filter.
Aug 06, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Bosch washer wont drain wvf 2401
You need to locate and clean the pump filter, usually found at the bottom right front of washer, sometimes behind a removeable plastic cover at the bottom.
Please rate my solution.
Thanks.
Nov 20, 2009 | Bosch Washing Machines
It wont unlock after giving me the f04 code... cause it has water in it but i need to open it! it also the drum wont spin
sounds like your water pump has failed or blocked position your drain hose on the floor into a bucket or floor waste let water drain out you should be able to open door reposition drain hose in original position and try again if drain pump does not work check for blockage or replace faulty pump good luck
Nov 04, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
Jan 26, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Plastic cover over the glass is broken
If the unit is brand new, most companies offer a 30 or 60 day cosmetic warranty, so you should be able to call your local authorized bosch service company and have them out to repair it under warranty. At the very least, your owners manual should give you a number to call for service, and they should be able to order you the part and tel you how to install it. Hope this helps.
Jun 18, 2007 | Bosch Nexxt WFMC330SUC
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
