Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
I have a Jazzy 1113 ATS .The batteries are bad .I charged them individily on a different charger .I plugged the onboard charger in but do not get a voltage reading on the plug to the batteries .
  • 692 Answers
Huntin you might not get a reading at the plug to the batteries because if its not connected to a load the charger might operate until it senses a load. a better way to check would be to plug the charger into the outlet and take your meter set it to 200 volts dc and plug it into the two outter holes of the chager port located under the front of the joystick. you should get 27-30 volts dc with the charger plugged in. when you unplug the charger you will be reading the battery voltage. After charging overnite you should be reading 26-30 volts dc if you aren't getting that voltage replace the batteries Hope this helps
Posted on Mar 24, 2011
Testimonial: "Thks for the info.It was real helpful in finding the problem with my Jazzy 1113 chair ."
Just replace batteries. Technician took out onboard charger because wires were frayed. Gave me external charger to use. Now indicator lights up as fully charged, but chair won't move.
Hello, this may be a late answer. I would have returned to the technician for answers, also. It may be possible to regenerate batteries so hang on to them until you have them tested. Hope this helped .
Mar 28, 2016 | Pride Jazzy 1113 ATS Indoor Power...
Can the batteries or my charger be bad on my Pride Jazzy 1113 ATS?
The MK batteries are far superior to Interstate batteries overall.
You can load test the batteries to see if they are working properly with a load tester. Your can test the charger output to the batteries with a digital voltmeter connected to the batteries with the charger plugged in. These 2 tests take less than 10 minutes and can be done at a local auto or scooter shop for nominal expense.
Make sure the charger and battery connections are tight and free of corrosion. On the VSI of the Jazzy 1113 there is a notorious problem with 8 pin connector and 3 pin molex at the back. You can clean these connectors but a complete electrical rebuild of the pins and receptacles is sometimes required if significant corrosion has set in. Try spraying electrical cleaner and use green Scotchbrite to clean the metal tabs on the 8 pin connector. Make sure the 3 pin molex sits in the receptacle and is making good contact.
Hope this helps.
Jul 22, 2014 | Pride Mobility Products Jazzy 1113 ATS
Should power be turned off while charging the jazzy 60
Doesn't matter. When you plug in the charger it automatically shuts off power to the scooter. If it doesn't then look inside the charger plug for a broken wire
Apr 25, 2014 | Pride Jazzy 1113 ATS Indoor Power...
Will not charge up has been sitting for along time.
You need to charge each battery individually with an automotive NON automatic battery charger until at least 10 volts is reached. The chair charger will not charge a battery unless that voltage is present.
Sep 20, 2013 | Pride Jazzy 1113 ATS Indoor Power...
I have a 1992 jazzy 1113 ats wheelchair and i accidently locked it the other problem is that the only way i can get the controller on is to plug it into the onboard charger and then a green light and a red...
Aimeelynn I'm e-mailing you the unlock procedure for a VSI controller. If thats not what you have you can e-mail me back the type of controller you have. I will also try to answer the other questions you have
Nov 07, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Have a jazzy 1113. The speed profile lights flash then the chair shuts off. The batteries show full.
The flash of the speed lights indicate that you are in the charger inhibit mode and if the charger is not plugged in then you have a problem that needs to be checked by a tech or your provider that sold you your chair Sorry I don't have a quick fix
Sep 25, 2010 | Pride Jazzy 1113 ATS Indoor Power...
The onboard charger on my Jazzy 1113 does not work after replacing the gel batteries. Do I need to replace the onboard charger?
If you have checked the charger and are sure it isn't working. Then you have two options: You can buy a new on-board charger or try to locate a good used off-board charger from someone in your local area. Or maybe borrow one from a neighbor that has a power chair to see if it will charge your batteries. You just plug the off-board charger into the charger port located under the front of your joystick. Off-board chargers should be cheaper than an on-board from Pride. Hope this helps
Aug 27, 2010 | Pride Jazzy 1113 Power Chair
Wheelchair charger blinks in green despite connecting all the cord. What is wrong
Charger is charging should turn solid green when fully charged if not the batteries are bad or charger is not working correctly
Aug 05, 2010 | Pride Jazzy 1113 ATS Indoor Power...
Jazzy 1113 will not charge, batteries are new, light blinks indicates charging when plugged in but fails to increase usage lights.
Most likely your charge isn't charging properly. You need a multimeter to test the voltage at the joystick. In the 3-pin femal connector measure the voltage across the two horizontal terminals. It should read about 24 volts. Now plug it into the charger and see if the voltage increases, if not, charger needs to be replaced. You can get one that plugs into the joystick on ebay a lot cheaper than going to the mfgr. about $50.00 or so. Even if the lights are blinking, it may not be putting out sufficient voltage to bring the batteries up.
Dec 30, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
139 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
