I am opening Outlook 2003 and I am getting the following message: There are no office assistant character files present on the system. Please run setup in maintenance mode and install at least one character. The message allows me clicl OK and continue but it is really annoying to have to click it each time I load Outlook. Can you tell me how run the maintenance mode setup?
  • gregg555 Mar 24, 2011
    So I guess a reboot and watch the order of when you start applications is the answer.
    Thanks
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links to get the solution it's an official site of Microsoft..:-
http://support.microsoft.com/kb/837825
http://support.microsoft.com/kb/839132
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 24, 2011
Cannot open
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem
Important notice for users of Office 2003:
To continue receiving security updates for Office, make sure that you're running Office 2003 Service Pack 3 (SP3). The support for Office 2003 ends April 8, 2014.
If you're running Office 2003 after support ends, to ensure that you will receive all important security updates for Office you need to upgrade to a later version such as Office 365 or Office 2013. For more information, see Support is ending for Office 2003.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
On the Change Office User Settings page, expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box.
For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
More information
When you run the Custom Installation Wizard, on the Change Office User Settings page , you can make changes to any Office user setting on the computer where this MST is deployed. When you click Miscellaneous PST Settings, you can specify a default location for .pst files.
In the Default location for PST files box, you can use environment variables such as %USERPROFILE%. For example, you can give the location %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
However, you cannot specify a file name instead. For example, you cannot specify %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\%USERNAME%.PST.
If you do this, an error occurs when you try to start Outlook.
Jul 04, 2013 | Computers & Internet
When opening Outlook I receive the following message, this occurred after I tried to email a photo out of a photo program: "A data file did not close properly the last time it was used and is being...
1. In Outlook 2007, click the Tools menu and select Options.
2. In the Options dialog box, click the Mail Setup tab and then click the Data Files button.
3. In the Account settings window, you will see all of your personal Outlook data files listed. Here, you want to note the full path to each data file. On my system, my Outlook personal and archive folders are stored in the C:\Documents and Settings\Your Username\Local Settings\Application Data\Microsoft\Outlook folder.
4. Once you have this information, close the Account Settings dialog box and then close the Outlook Options window.
Now that you have the location of your Outlook data files, you need to check and repair them using the Microsoft Office Outlook 2007 Inbox Repair Tool-SCANPST.exe. By default, you should see SCANPST.exe in the Microsoft Office installation folder's "Office 12" subfolder. On my system, SCANPST.exe is located in C:\Program Files\Microsoft Office\Office 12. For additional information on SCANPST.exe, take a look at the Microsoft Knowledge Base article, "How to use the Inbox Repair Tools to recover e-mail messages in Outlook 2002 and Outlook 2003."
To check and repair your Outlook data files, follow these steps:
1. First, close Outlook 2007.
2. Use Windows Explorer to browse to SCANPST.exe, then double-click it.
3. When the Outlook 2007 Inbox Repair Tool opens, click Browse and navigate to the Outlook data file location that you found earlier. Note that you will need to check each file listed. On my system, I start with the file archive.pst. To check that file, you would select it in the "Select File to Scan" dialog box and then click Open.
4. Now click Start to begin the repair process.
Mar 05, 2011 | Sony Microsoft Office Standard 2007
When i open microsoft outlook i get a message Microsoft outlook has not been installed for this user. Please run setup to install application. please tell me how to clear this?!?!?
The microsoft outlook program was not installed during your initial installation of your microsoft office 2003 suite?
Use your initial installation CD and just follow the installation wizard.
Jun 30, 2010 | Microsoft Office Outlook 2003 for PC
Logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any...
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
Outlook 2007 not starting. Error message says corrupted file. Run Scnpst.exe.
As an old Outlook user (for over a decade). I ever met similar error with my Outlook PST files before and got it solved with this Outlook PST repair software, the software extracts & restores those inaccessible Outlook items in a new .pst file and enables complete Outlook data recovery. If you want to take the most effective way, then try that program. Hope it helps too with your case.
Apr 12, 2010 | Computers & Internet
Opening contacts from outlook 2003 in outlook 2007
you can try this, not sure if it will work, browse to this site, and upload you .dat file
http://www.winmaildat.com/
you can save it as an excel spreadsheet i believe and then use Outlook to import from a .csv and import your contacts that way....
If you need help please let me know,
Thanks,
David
Mar 01, 2009 | Microsoft Office Outlook 2007: Windows
Outlook Free/Busy error
Hope this solves it for you! Here's the official word from Microsoft:
If you receive one or more of these error messages, you may experience performance issues until Outlook finishes the reconciliation process for the .ost file or for the .pst file. The following gear icon is displayed in the status bar while Outlook checks the data file in the background: Collapse this imageExpand this imageol2007gearicon.jpg When this icon disappears, the .pst file or the .ost file is reconciled. If you exit Outlook while the gear icon is present, reconciliation must restart the next time that you run Outlook. We recommend that you leave Outlook running until the gear icon disappears before you exit Outlook.
An incorrectly shut down .ost file or .pst file may occur for one of the following reasons:
  • Antivirus scanning of the file
  • Forced Microsoft Windows shutdown before the Outlook.exe process shuts down completely
  • Outlook add-ins
If you see this issue frequently, and you have to exit Outlook shortly before you shut down your computer, it may be better to shut down Windows while Outlook is still running. We recommend that you do this instead of exiting Outlook and then shutting down Windows shortly after that.
Jan 03, 2009 | Microsoft Office Outlook 2003 for PC
Personal Data File did not close properly
  • Outlook add-ins
Dec 26, 2008 | Microsoft Office Outlook 2007: Windows
Microsoft office
When you try to start a Microsoft Office 2007 or Microsoft Office 2003 program, you may receive the following error message or an error message that is similar to the following:
Error 25090. Office Setup encountered a problem with the Office Source Engine, system error: -2147023836. Please open SETUP.CHM and look for "Office Source Engine" for information on how to resolve this problem.
CAUSE
This behavior occurs when the following conditions are true:
* Two people installed Office on the same computer.
* Both installations were completed by using the AllUsers="" parameter to set the installation for the installing user account only.
* When both people were prompted to remove files that were copied locally at the end of Setup, both people did not remove the files.
* One of the two people removed Office.
RESOLUTION
To resolve this behavior, start the Setup program for Office. To do this, follow these steps:
1. Insert the Microsoft Office 2003 CD in your CD drive or DVD drive.
2. If the Setup program does not start automatically, locate the Setup.exe file on the CD, and then double-click the file to start Setup.
3. After the Setup window appears, cancel Setup, and then respond to the prompts to exit Setup.
Note: You do not have to complete the Setup program. Setup fixes the error condition when it is first invoked.
Sep 05, 2008 | Microsoft Office Outlook 2003 for PC
Unable to open e-mail attachment
Open Files with .MSG File Extension Do you want to open a message with the Outlook .MSG file extension? The Encryptomatic MSG File Viewer makes it easy access Outlook MAPI message files (.msg files) created in Outlook 2000/XP/2003.
MSG Viewer reads .msg files encoded in western characters. It will display the text contents of the .msg file on your monitor. You can also print the message, save it to a text file, and extract file attachments.
Easy to Use Encryptomatic's Outlook .MSG Viewer is simple to use. It may be optionally installed as the default .msg file handler. This enables you to display a .msg file by simply double clicking it.
Extracts File Attachments from Outlook .MSG Message Files
Users can extract and save to disk any file attachments that were included in the Outlook .msg file, a useful feature not found in other viewers of this price class. To extract email attachments, just double click on the file attachment and save it to a directory.
viewer-screen.jpg What it Doesn't Do
The MSG Viewer is designed to give you quick access to an .msg file's text contents, file attachments and header information. It does not render colors, formatting or graphics, and it is not a full featured substitute for Outlook. With an RTF message with colored text and font formatting, the text will appear in black and white and the paragraph formatting will be lost (as in the message above). MSG Viewer displays only Western characters.
Feb 26, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
