Question about Texas Instruments Office Equipment & Supplies
TI-5032SV Can't get the paper threaded in through the back... what am I doing wrong?
How do I thread paper?
Hi Sharon,
Here's a link to the manual that will download automatically as an 5032svc.pdf (an Adobe PDF file). It contains the instructions that you're seeking:
5032svc.pdf
Apr 14, 2015 | Texas Instruments TI-5032 SVC Calculator
How do I install ink cartridge for TI 513011 calculator?
I think that you probably meant to say "TI-5130 II." The two last characters are capital i's-not 1's.
The ribbed edges along the top of the paper roll cover are for gripping the lid with a thumb & sliding the cover back-in the direction of the arrow that is also featured on the cover. 25300620-iv4burzhkawezvl2jbah1xae-2-0.jpg
Insert a new roll in the space provided-between the clips. Power on this adding machine by plugging the electrical cord into a standard power outlet. Feed paper through the jagged tear-off edges of the paper roll's path by pressing the dark gray paper advance key at the top to the right of the LCD display. Slide the cover back on.
Nov 29, 2014 | Office Equipment & Supplies
How do i load roll paper on TI-5033II
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding back in the direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the calculator. Press the paper feed button until the paper is in the printing position.
A PDF version of the manual is available at:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCcQFjAB&url=http%3A%2F%2Feducation.ti.com%2Fmedia%2FE152CF808E0C46759750698A1FCC970F%2F5033sv&ei=tA9EVLWbIMKcigLO-4CABQ&usg=AFQjCNF6zdaotZAIlF-6DajAVKg0UMh54w&bvm=bv.77648437,d.cGE&cad=rja
Oct 19, 2014 | Office Equipment & Supplies
How do i load my printer paper ti-5045sv
To load paper into a ti-5054 sv calculator.
  • Turn Calculator on.
  • Press down on the front edge and slide in the direction of the arrow.
  • Insert paper on the roller so that the paper rolls out toward the bottom, and the loose end is closest to the calculator.
  • Cut of the end of the paper.
  • Insert the end of the paper into the printer slot in the back of the calculator.
  • Press the paper feed button ( karmahm_0.png) until the paper is in position.
Mar 17, 2011 | Texas Instruments TI-5045 SVC Calculator
I have a singer touch tronic 2001sewing machine. I put the material to be sewed down, put down the foot and when I tried to sew, after a few stiches, it pulled the materal down and locked up. I pulled...
What type of material are your trying to sew? If it is stretchy, or thin put some gift wrap tissue paper under it to stabilize it. Also, adjust your tension to about 2 or 3. Now check your needle, put a fresh one in, maybe a 9 or 11. Do not use old thread, either because it breaks easy. Try this, I hope that it works for you. You can buy stabilizer, pellon but tissue paper is what we used years ago, sometimes even computer paper. Good luck.
Nov 10, 2010 | Singer Sewing Machines
Machine apppears to be working correctly,but when i look at the material ,there are absolutely no stitches whatsoever,its threaded correctly and the needle seems to move up and down with ease.whats wrong?
U seem to be novice. Remove the bobbin and make the thread coming out from it just about 3 inch long.(preferably do this test with a different color thread in the bobbin) Place it back in position. Now if u can run the machine by hand and make the needle just go once in and then out, it should come back with thread from the bobbin.
If this happens , your machine is in order and it should stitch properly.
If not, then you need to supply more info about this.
if u r a novice please show ti it to any tailor, even if he doesn't know such machines. he should be able to pin point the problem.
In all probability there is surely some problem in threading or fixing of bobbin.
Lastly did you did not mention if you have use this machine before and was every thing alright?
Oct 17, 2009 | Sewing Machines
Wrong trig ratio
Your calculator is set in radians. Press mode key. Arrow down to 3rd line. Highlight degree and press enter. Your calculator is now in degrees, not radians. To get out of the mode screen and back to home screen, press 2nd and then mode.
Aug 05, 2009 | Texas Instruments TI-84 Plus Calculator
104 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
