Question about Ducane 30400040 Stainless Steel Grill
Replaced burners flame flutters in middle and far right side burners then goes out
    Master:
  • 403 Answers
Bad regulater in fuel line, replace the whole thing
Posted on Mar 24, 2011
Hot water tank doesn't stay on
Suspect the thermocouple that senses that the pilot is lit. This device prevents the gas burner from coming on when if the pilot goes out, but if it's defective could cause the burner to shut down even when there is a pilot flame. Also check the position of the thermocouple in relation to the pilot flame. The tip of the thermocouple should be right in the middle pilot flame.
Oct 11, 2013 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Buners will not Fully Light
A burner doesn't work Heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in two, or blisters and bubbles.
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too. Also see the "A burner works only intermittently" section, next.
http://www.repairclinic.com/0088_13_1.asp
Jun 29, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Amana Gas Cookertop flame goes out on burner but gas keeps flowing
which burner goes out on you when you use it. the front. the back. the left side. the right side. or all of them
Jan 04, 2013 | Kitchen Ranges
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
I have a 3 burner CaptnCook gas grill. The middle burner has a single flame when I try to light but does not light the whole burner row, just right at the front only. The right and left will not light at...
The problem lies with the grill's regulator and how the gas tank valve was opened.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Aug 23, 2011 | Barbeques Galore Capt'n Cook 3-Burner...
G4-7 atwood water heater lights great, heats water but when it cycles the pilot goes out no hot water
Sounds like the burner flame may be too strong (jumping out from burner tube) . Some people think the louder the better, but that is not correct. When burner shuts down like that, it has a tendency to snuff out pilot as well. Adjust your air shutter at burner so that the flame is a nice blue, or with just a hint of orange/yellow at the tip. Whatever setting that keeps the flame solid from burner tube, and not a big gap between tube and flame. Signs of soot (black) up the cover, or side of trailer means it's running too rich, and you've gone too far thus needs more air. Keeping the flame blue but still right out of the burner, actually heats better, is quieter, and should eliminate that pilot getting snuffed out. Pilot should also be a nice blue flame as well. There may be a problem with positioning of the burner tube as well, but doubtful if it has been running well in that position before. Let me know what happens.
May 10, 2010 | RTO Atwood Water Heater - 6 Gal LP
Fire inside burner
Hi looked on the wedsite it sounds like the air mixture is wrong casuing it to light back on to the injector (ORFICE) A slong as the orfice is clean and the burner is not blocked then the screw on the burner should adjust the air flow , turn it out as far as it will go with the burner on adjustthe srcew keep tuning slowly in , if it lights back it might make you jump but it won't do any harm , its just getting the mixture right, try this and see if it works ,
Jan 20, 2010 | Heating & Cooling
Furnace lights than goes out after 5 sec over and over Weather King 80pj series
There is a sensor called a flame sensor that is located in the burner box either far right or far left and will be in the flame of a burner. There will only be one wire to it. It sometimes collects carbon and may need to be cleaned. The circuit board only allows a very few seconds for the flame to travel from the pilot or ignitor to each burner. If one or more of the burners are dirty, it will slow down the flame travel. Watch as each burner ignites and travels down the line. You can take a can of compressed air and blow out the burner tubes but be careful around the ignitor as it is very delicate. Once you have found the flame sensor, use a toothbrush or scotch brite pad to polish it. Check the wire connections at the sensor and board. Also look at all wiring connections from board to cabinet ground. Good Luck.
Dec 29, 2009 | Weather King 10AJA6001AH Air Conditioner
The burner comes on but goes out after 2 seconds
Your flame sensor may need cleaning. It is a sensor located in the flame of a burner far right or far left in the burner box. Use a tooth brush or scotch brite pad. Do not attempt to clean the igniter as it will break.
Dec 29, 2009 | Goodman GMS80453ANA Open Flame Mid-Size...
I have a Intertherm furnace model MMHA with United tech controller 1018 HSI. Flames starts up , fan runs but flame goes out and restarts after a few minutes. Keeps doing this, I don't see a proof of flame...
Maybe. There has to be some sort of flame sensor with this HSI module. Look on the wiring diagram for where it may be. If this model has a pilot that starts before the burners, it may be part of the ignition electrode or glow bar. If the burners just light, look at the far end of the burner box to make sure the flame is traveling down the entire length and hitting the sensor. If you find it, clean it off with a small tooth brush. Blow out the flame rail where the flame travels from burner to burner. Clean off the pilot assembly if it has one.
Oct 17, 2009 | Heating & Cooling
Ducane 30400040 Stainless Steel Grill Logo
69 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
