Windows always giving notification bad hard disk
  • 107 Answers
Bad Hard disk means a lot of disk partition is damaged and you will have to do a **** check to see how damaged the disk is for disk check and trying to repair it. the command Chkdsk can repair problems related to bad sectors, lost clusters, cross-linked files, and directory errors. log on with administrator rights and open My Computer then left click and now click down on properties, click on the Tools option and Click Check Now then select both the Automatically fix file system errors and the Scan fro and attempt recovery of bad sectors, click Start and Restart...During Restart allow the scan to take place, it will take some time but it is worth waiting. Another simple way to run the disk check is by entering the command Chkdsk in the command prompt, click start then click Run then type in CMD after the command prompt appears (normally a window with a black classic display) type in the command Chkdsk after check is done enter Chkdsk /f ......(to fix the errors)
Posted on Mar 24, 2011
Testimonial: "yes i have done what is told in this solution and my problem is resolved. thanx"
When My 8gb drive is connected then notification given is USB device is malfunctioned and windows does not recognize it. So it does not allow me to get access so give the appropriate solution
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Dec 26, 2013 | Kingston 8GB Data Traveler - 108:...
I have 4 Gigs Kingston data Traveller, but everytime I plugin to USB always shown notification to format the Flashdisk. And it's always 'Windows can not format it". How can I repair the...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
Jun 19, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
A notification stating HDD is to fail. where do I have this repaired or replaced? thanks,
maybe you HDD system is corrupted, try to recover it if your can....
otherwise,back up your important files and format,re-install new system software..
Jun 05, 2011 | Toshiba Computers & Internet
System will not boot to windows, screen lockup with screen indicating BIOS Revision 1.0.13 and F2 and F12 function option keyboard not responding to functions.
This is usually a good indication that something is wrong with either the hard disk or CD/DVD drive - but almost always the hard disk.
Disconnect the hard disk, and see if it will boot to the point that it gives an error that the hard disk is missing.
If it does, try another hard disk in the system.
If not, post a reply to this solution, and I will advise on other possible issues.
Jun 04, 2011 | Dell Inspiron 530 Desktop Computer
Boot error always
Hello sir, hi your boot error can be caused by the following:
  1. Your IDE hard disk is not the first boot, and wrong available boot on the bios. Check your BIOS setup for proper boot device.
  2. Your IDE hard disk has bad serctors, since its P4, I estimate your drive to be 8 years or more. You may need to format the hard drive again and reinstall your OS (windows XP).
  3. IF your HD cannot be formated, or no amount of windows installation can be done on the disk, its time to replace it.
  4. Your IDE cannot be detected by the motherboard. check your BIOS configuration for proper hard disk setup.
  5. Your IDE hard drive and your CD drive are both master or both slave, set the hard disk to master and the CD drive to slave. The settings can be seen on the case of the HD and CD drive.
  6. Your IDE ribbon cable is bad.
  7. Your 4 pin molex power cable to the HD is loose.
If I miss out something, please let me know. thanks.
Nov 08, 2009 | ASUS P4S8X-X Motherboard
Unable to repair windows 2003 on hp proliant ml 150
Attach an external hard disc and put all your data in it. If the PC came with this OS then hp must have given a rescue disc, use that to boot and follow the instructions on the screen.........sodeep
Jun 17, 2009 | Compaq Refurbished SYSTEM I/O W PROCESSOR...
Bad hard drive back up and replace on evesham ebox
The only thing I can think of is you might hook up the drive as "slave" drive on a working computer and see if it will operate long enough to retrieve your data. But if the drive is dead you may have lost everything that was on it. There are services that do data recovery on dead hard drives but I'm sure it is expensive to have this done. This is why I always back up everything I do to a different device while I am working.
Jan 16, 2009 | Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Slow Speed and Hard Disk LED "Stuck" on...
This has happened to me a few times and it's been posted here by others, and the one thing that is always apparent is it happens after a windows update, this may well be a generic updated driver which is not always the best driver for what you have installed or it could be a programme that has not installed correctly especially windows genuine advantage. I would do a system restore to a point before the windows updates, then go to Microsoft updates yourself and manually install the updates that windows says you require one at at time until the same thing happens, although it may not as it may be the fact that there are too many updates trying to be processed at the same time causing the lag and permanant HD led light.
Oct 02, 2007 | Acer Aspire 1352LC PC Notebook
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
