Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower) flashes or dims in and out, and nothing happens. I then have to press and hold the on button until the system shuts off, but when I try it again, same problem happens. It was working fine earlier this morning, then all of a sudden, a long BEEP and the monitor went black (On light on the tower began to flash/dim).
    Sergeant:
  • 223 Answers
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Posted on Mar 24, 2011
  • Jean Thiebaux Jun 21, 2012
    I have googled your error beep code and it seems as if its a problem with your memory. I.T technicians will not admit to this but there is a little gremlin that loosens your memory (RAM modules) try reseat it, swap it around. Should that not work then replace it.
My gateway dx4860 ub33p is making 1 long continuous beep at start up not showing anything
Unplug power cable
Hold down the power button for 10 seconds
then remove power cable from the back of the computer and plug it back in.
try plug it directly to another outlet
that long continuous beep is a power issue
if you originally had it plugged into a power protector or multiplug connect it the outlet directly to get better power.
Jun 15, 2014 | HP Compaq dx2300 Microtower - RT950UTABA...
Gateway M275 doesnt turn on
unplug it from the wall, remove the battery, hold the power button down for 30 seconds, then plug the power cord back up and into the laptop and press the power button, if that makes a difference, replace battery and see if it continues to run
Oct 11, 2012 | Gateway M Computers & Internet
Screen went black,then said it was in power saver mode. Tower is on but nothing appears on monitor. what are the possible problems please. PSU or Hard drive?
Try hitting the power button on the monitor.... If that doesn't work make sure the i think "VGA" is connected... The cable with the blue thing on the end... make sure it is properly secured... in there.... There is nothing wrong with the hard drive.....
Jan 08, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
Loud gateway 5310 desktop
its your power supply that making nosies, change it to a quiet one. or its you processor fan. if so you need to clean it from dust. also clean your power supply and if you are lucky the noises disappears.
Oct 12, 2009 | Gateway 5310S PC Desktop
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Computers & Internet Logo
543 people viewed this question
Alun Cox
David Payne
David Payne
