Question about Vacuums
Steam isnt coming out of my iron as it should be any ideas thank you
  • 484 Answers
It may be bunged up with cal or bits. Fill the iron then heat it up to full heat, unplug. Then over a sink discharge the steam from the bottom in one go. Or buy a special cleaner.
Posted on Mar 24, 2011
Build up of deposits when steam iron is used, how do you get iron apart ?
You might be able to clean out your steam iron by putting vinegar in instead of water. It has worked on my steam iron as well as my coffee pot.
Jun 26, 2011 | Vacuums
Steam advantage iron has no steam coming out when ironing. Reservoir is full of water. some calcification showing on irons bottoms holes
you would probably get a better response if you didn't post your problem with your iron as a problem with your vacuum!
May 10, 2011 | Vacuums
Scrunci steamer no steam when the button (for steam) is pressed Vinegar has been used to no avail. Please advise. Thank you
Its most likely this iron is clogged with lime scale as you have already used Vinegar . Buy a lime scale remover liquid , mix it with hot water. And pour it into iron leave for 24 hours then empty , clean iron out to get rid of any lime scale solution. And try it again..
Hope this helps.
Apr 14, 2011 | Scunci 52067 Handheld Steam Vacuum
There appears to be a yellowy brown discharge that appears on my shirts when I iron. It doesn't happen all the time. How do I fix this?
Hi and welcome to FixYa, I am Kelly
Your iron is building up calcium deposits inside the reservoir and occasionally they flake off and into the steam system along with any minor releases of steam and it is showing up on your garments. There are commercial products in the market place for cleaning your iron.
This is one product:
http://www.google.com/search?q=Steam+Iron+cleaners&hl=en&safe=off&sa=X&rls=com.microsoft:en-ph&tbm=shop&prmd=ivns&tbs=brand:whink&ei=5_CWTevuNI-qcZe1masH&ved=0CJEBEMEJKAAwDg
This is another one:
Siege Chemical 776L Steam Iron and Showerhead Cleaner
http://www.siegechemical.com/00_cart_console.php?prod_id=522
It can be purchased from this page:
http://www.siegechemical.com/00_cartpage.php?cat=S-M
Thanks for choosing FixYa,
Kelly
Apr 02, 2011 | Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
Steam builds up but does not come out of the iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Jan 19, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Does not give steam.
Actually there was no category for clothes steamer, and before entering information I was prompted to pick a category so I chose vacuums hoping that when my problem was diagnosed it would be understood that the problem is a clothes steamer that has stopped giving off steam. Please help if you can. I appreciated your time.
May 20, 2009 | Westinghouse Vacuums
Euro Steam Iron Mod. 4488
My 4488 euro steam will not heat up?? All connections etc have been cut and reconnected. Power light is on! Any ideas????
Apr 10, 2008 | Vacuums
Vacuums Logo
63 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
