Question about Sony STR-DE425 Receiver
Sony Stereo Receiver - STR-DE425 Loud pop and "PROTECT" Flashes. When I turn it on and off several times it finally stops. What do I need to do to find out what the problem is? This happens about 80% of the time when I initally turn on my TV.
    Brigadier General:
  • 8,546 Answers
Toggling power on and off is NOT a good idea, nor does it ever really fix anything.
Does the TV affect the receiver even if you have other sources selected or speakers disabled?
Establish if the TV connection or lack of it affects the problem by disconnecting one cable at a time (I have no idea what cables you use) to see if the self-protection is caused when the TV is turned On. Prove that each cable is or is not involved with glitching the receiver. If it still pops after the TV is completely floated from the receiver, consider a power surge as the culprit. Maybe you need to place the receiver on a power circuit that isn't shared with the TV.
Oh, btw, you're not drawing power from the convenience outlets on the reciver for anything that sucks up a lot of juice, are you?
Posted on Mar 24, 2011
Sony receiver stR se-501 found fuse burned after replaced turned on the flashing massage PROTECT come on . Did I miss anything?
Protect typically means that the fuse blew because something in your receiver went bad. It's now protecting your speakers from that badness. You need to get the receiver fixed or replaced.
Jun 16, 2015 | Sony Str-Se501 Stereo Receivers
I was playing some music pretty loud today on my Sony STR-DB790 and then no bang no crackling just strait to protect mode turned stereo off thinking nothing of it and now every time I turn it on strait to...
There is an output load causing the protect to engage, turn unit off and dis-connect the speaker wires from the back of the receiver, this will reset the processor ic. Now power on and turn volume right down, if the word protect stays off it means there is a short in the wires or one or more of the speakers. But if the word protect comes on with the "speakers and wires dis-connected" it indicates a short in one or more audio output ic's and will need a tech to address the extent of damage and cost.
Feb 06, 2011 | Sony STR-DB790 Receiver
Sony receiver made pop noise and all sound systems went mute.what are my options? STR-DE425 sony receiver with surround sound, dvd player,cd player and tv all connected thru receiver...
It sounds like the output ic's may have failed, because of the complexity of system I would have a professional come and look at the unit for an evaluation, chances are he will need to take it back to the shop for service.
Dec 30, 2010 | Sony STR-DE425 Receiver
PROTECT ON FLASHING
audio amplifiers Ic´sdamaged need to be replaced
May 22, 2010 | Sony STR-DE425 Receiver
PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
I have this unit but after i put the volume high
Posibly bad speaker. How many speaers are you running on this receiver?
Jun 01, 2008 | Sony STR-DE425 Receiver
Hooking up amps
kolko glup trebas bit? otput iz DVD u input u sony video, output iz sony video u tv
Dec 05, 2007 | Sony STR-DE425 Receiver
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Goes immediately into protect mode
Yep. The wiring to your speakers or the speakers themselves have shorted out. You have a blown fuse. You'll need to either replace the unit or attempt to replace the fuse yourself.
Sep 10, 2007 | Sony STR-DE425 Receiver
Sony STR-DE425 Receiver Logo
513 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
