Question about Nokia 6630 Cellular Phone
Microphone not working
For the last 3 days am having problem with my 6630,its microphone is not working.whatever am speeking is not listened at th e other end,presently am using my head phone toovercome this,please give me som support to solve this problem.pls mail me ak.prasoon@gmail.com
    President:
  • 1,952 Answers
It may be pro in ur microphone transmitter and receiver..tis can b available in the node connect between two ear speakler..so better check tat
Posted on Aug 07, 2008
Why would my laptop speakers randomly start screeching like at a concert when someone turns on a microphone?
Usually means that your settings are set to broadcast (or listen to) your microphone... If the sound from your speakers is being picked up by your mic, and your speakers are outputting the sound from your mic, it will manifest itself as a lot of wailing.
either turn your speakers down, or disable the setting that makes you be able to hear whatever sound is coming from your microphone (it's a checkbox labled "listen to this device" in most modern windows sound configs)
some drivers have a echo reduction option, turning this on may also help
Jan 11, 2014 | IBM ThinkPad Computers & Internet
I hear my own voice when I talk on Logitecs H600 wireless headset
IF you are in Windows 7: -
1. Click "Control Panel" > "Sound" > "Recording"
2. Place cursor over "Microphone - Logitech Wireless Headset Default Device".
3. Right Click and select "Properties"
4. Click the "Listen" Tab
5. Uncheck the "Listen to this device"
6. Click "Apply",. and "OK"
That will eliminate you hearing any nose picked up by the microphone. Others will still be able to hear your voice as long as you have the headset as your default microphone.
Mar 02, 2013 | Logitech (980408) Wireless Headset
I have a Pavilion dv6-3025dx and cannot get the sound to work for skype. Obviously there is a camera and that works fine but I could not get the audio to work - do I have to add a microphone. Can you help?
I understand that you are not able to us the microphone with Skype. As per the information provided in User Guide for the model it seems that the model has an Internal microphones .
Try configuring the internet microphone to use with Skype.
Open Skype - Tools - options- Audio settings- Set the input device as internal microphone and check the operation.
Aug 22, 2011 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
Hello. I have a HP ProBook 6540b. Serial : CND022091X Product : WD691ET#ABN The built in microphone desn't work. Dependant on Skype due to my work. Where could I find the software for...
Im pretty sure it does not require a software for the microphone driver, neither do you need a driver for it.
its very simple, if you can hear audio (music or whatever) you have the soundcard driver installed successfully and if so we are one step closer to solving this issue.
Listen to me and listen carefully! This is a step to step guide.
First off, press the following. (start - Control Panel ((make sure you have small icons for win 7 / vista)) click on sound, go to the Recording Tab, there you should find the microphone for your HP Laptop, make sure its set to default. were not done just yet. Make sure your microphone is selected and press "properties" and go to "custom" the microphone boost is good to have selected. now continue on and go to "Levels" make sure its not silenced or set on low.
Thats should do the trick, hope it worked!
Cheers =)
Jul 07, 2011 | HP ProBook 6540b Notebook
I hav a microphone problem.Its working properly on my pc,but when when i connect it to my social netwoking site it doesnt work properly,some wired noice comes out th speaker of th one who is listning to my...
Go on mic. configuration and select on microphone use from configuration mic. name and test the mic. On test mic not works mic,is posible to need a driver for mic and need download and install the driver.
Jul 30, 2010 | Computers & Internet
Skype video using Acer Aspire Mini Laptop camera?
If you have a WEB camera you need to configure your video Webcam settings. Open Skype click on Tools - Options - Video Settings - select your Webcam model. When you open Skype click on Tools - Options - Audio Settings and click on Microphone and select the microphone you are using and save the setting.
If you still have problems with your mic. then - To test if the microphone is working, go to Start - Programs - Accessories - Entertainment - Sound Recorder and record you voice. Can you see your voice recording, the green line should vary as you speek.
If you see a flat green line, then the microphone is either faulty or the wrong microphone is selected.
Jun 15, 2009 | Acer Aspire One AOA150-1949 Laptop
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Wiring diagram for accessory plug needed.
I am looking for the same wiring diagram. The headset Moto sells is a single earpiece with microphone, so how does that end up being a stereo connection Neto? Just curious how, or is there also a full headset with microphone? ( I dont' know, just asking)
Would this be a 4 ring TRS connector? Sleeve = ground, then left, right, and the tip as the microphone??
Jan 18, 2009 | Motorola Talkabout T5420 (14 Channels)...
I cant talk
-> make sure mic is connected correctly in the correct slot to the CPU
->go to control panel-> sound and audio and there is seperate tab for "microphone"-> have th volume to be full
-> you can test whether the mic works there itself.
Nov 10, 2007 | Labtec C-322 Headset
Nokia 6630 Cellular Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
