Question about Car Audio & Video
Hi there i bought a car with a audiobank cd/dvd bluetooth player. for some reason when i try and pair my nokiae71 with car radio it ask for a pairing code of which i dont have. how can i get a pairing code as i even tried resetiing car radio
thesoundman
  • 41 Answers
SOURCE: aftermarket 6 x 9's
What type of car is it? You can purchase speaker harnesses at any car audio shop that will allow you to snap into the factory plugs. Also, beware if your system was designed for 8 ohm speakers - using 4ohm speakers instead could cause some problems. Most aftermarket stereos are designed for 4ohm speakers, but some factory stereos designed for 8ohms could be damaged if you give them a smaller ohm load.
Posted on Sep 21, 2007
SOURCE: pairing
0000 Should be the code
Posted on Nov 05, 2007
SOURCE: need a pin code
0000
Posted on Jan 07, 2008
SOURCE: Motorola H505 Bluetooth Pairing - pass code
try typing 0000 for the pass code
Posted on Dec 30, 2008
trillian_tx
  • 4 Answers
SOURCE: bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Posted on Apr 14, 2009
I got a Sharper Image Bluetooth speaker system and it didn't come with a manual, I can't figure out how to set anything, (radio stations, bluetooth pairing, clock etc) it asks for a code when pairing
easy put your phone or device on and the other device look for it in the scanning option and pair its normaly asks for a pin that is the pin they give you with the phone for the bluetooth option 00000 is standard
Dec 28, 2013 | Sharper Image Portable Speaker System Dock...
I can't find the codes for bluetooth pairing.
Normally, the 'factory default' paring code for a new bluetooth device is - 0000. Try this first.
If 0000 doesn't work, then try resetting the cd player back to factory settings (contact the manufacturer for further assistance).
Nov 28, 2011 | Car Audio & Video
How do I connect the bluetooth from the radio to my phone?
This radio is Bluetooth "Ready" and will not pair to any blue tooth device until an additional peice of hardware is purchased and installed. Page 13 of the manual describes this as a "Bluetooth HANDS FREE BOX.
Unless you have purchased this and installed it - pairing is not possible. I hope this helps & good luck!
Mar 23, 2011 | Kenwood KDC-MP238 CD Player
Tring to install blutooth to my xdma7715 dual cd player
The Dual XDMA7715 unit does require a separate module called the Dual BTM60, as technically the XDMA7715 is a "Bluetooth Ready" cd player.
Assuming you have bought this module, the next thing you need to do is 'Pair it" with your mobile device, which I will assume is your cell phone. This keeps it from connecting with other people's cell phones as they drive by your car.
Before you begin, you need to prepare your phone for paring. Check your cell phone's users manual if these instructions don't apply, but generally this means you find the Bluetooth menu on your phone, turn bluetooth on, and make the phone 'visible' which means your stereo will be able to see it in order to pair up with it. Usually, turning visibility on only lasts for about 30 seconds, so you may have to try this more than once to get the timing done right. Once paired, you won't need to turn the phones visibility on again until the next time you pair a device.
Now that your cell phone is ready to pair with the stereo,
1) Press the Phone symbol on the cd player or the BTM60, pr press MODE until 'DUAL_BTM60" is displayed.
2) Press and hold the phone symbol on the cd player or the BTM60 for 5 seconds, until "PAIRING" is displayed. The Bluetooth icon will flash every second. The Cd player will broadcast its "availability" for 60 seconds.
3) Complete the pairing from the Bluetooth menu of your cellphone by selecting "Search for new devices". When they find each other, the Bluetooth icon will illuminate solid, and your phone will say it has found device "DUAL_BTM60", and ask you for a password to pair it.
The BTM60 device name is "DUAL_BTM60".
The password you enter into your phone to accept the pairing is "1234"
Now that the devices are paired, you should be able to make calls handsfree, and play music stored on your phone.
I hope that helps.
Nov 24, 2009 | Dual Car Audio & Video
How do I connect my bluetooth?
Be discoverable on your phone. Have the Bluetooth (ON) on the XDVD8183 and click (Pair)
Then it will ask for a code on your phone to pair. The code should be either 9999 or 1234.
Apr 07, 2009 | Dual Electronics XDVD8183 Car DVD Player
Old phone would pair with Clarion VRX785BT's bluetooth
you auto connect is turning off on the screen. try keeping ur phone permantley visable.
Jan 10, 2009 | Clarion VRX785BT Car DVD Player
How to program bluetooth phone to sony radio cd player
Ok, I have a Sony MEX BT 2600. To pair my phone to the radio, I had to press and hold the BT button for 5 seconds until it flashes, then I have to search for devices on my phone. Xplod comes up. When it does, pair the two and use code 0000. That should do it. Also make sure the BT icon is showing, meaning it is activated for the Sony to connect. When conncted, the radio should show a phone icon for the BT Phone segment of the radio, and then another icon for the BT Audio, both should what looks like radio waves coming off of them, meaning the two devices are connected and recognizing each other.
Oct 26, 2008 | Car Audio & Video
How to use
These are IR headsets. I don't think they will work with a DVD player or Laptop, which usually just support Bluetooth.
Sep 03, 2007 | Myron & Davis AE-21 Headphones
Car Audio & Video Logo
322 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
