Question about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
Im John, I have a Phone "iphone copy", And my charger is broken.. Where to order the charger/battery charger for my A1221FCC. And its a Li-ion Battery that i cant identify at the web either, thanks.
  • 40 Answers
Try to look at http://www.dealextreme.com There you may order a new charger and battery (since they all seem to be unified, it will be difficult to buy a wrong one). The shipping is totally free.
The only problem is that since these items are extremely cheap, their quality is also very poor so they break a lot (Usually every third is malfunctioning). The battery also won't last any longer then half a year. And all this may explode one day due to absence of any protective circuits inside.
I don't say that you should totally avoid these, but precautions are definitely required.
Hope this helped!
Posted on Mar 24, 2011
Why won't my iPhone 5 charge?
if the charger is working and connected properly , it will charge with out the phone being switched on
check the charger with another phone or it could be a bad battery not accepting a charge
Sep 20, 2015 | Apple iPhone Smartphone
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
I dropped my Iphone 4s on the floor. The screen went black, and wont turn on. When i connect it to the charger is does not do anything. When i connect it to my Itunes it wont regonize it. what do i do?
I suggest you take your broken Iphone to a cell phone repair shop.
Get a quote for the repair then you can decide whether to go ahead with the repair or get a new Iphone.
Jan 28, 2013 | Apple iPhone 4S
How to remove battery from tvphone a1221fcc
At the top is a small hole, get your stylus and poke it into it and pull the cover.
Sep 11, 2017 | Apple iPhone Smartphone
A friend just gave me an lgcu720 phone. the phone is nice except for the fact that when ever im charging it it switches off (while still charging) and says insert battery. im not able to switch the phone...
Hello.
Bring it to a mobile phone store and inquire for a charger. Test it if it will charge your battery the way it should be, before buying it. If it doesn't charge properly in the store, then ask for new battery and test it also before buying it. That way you will know which is malfunctioning: battery, charger or both.
Jul 21, 2011 | LG CU720/ Shine 900mAh Lithium Battery...
Its an iphone copy, a1221fcc i need the internet settings will someone please help me
contact your service provider for their settings, you need to get the settings from them and put them in the phone.
Feb 25, 2011 | Cell Phones
I bought a portable charger for my iphone 3gs, my battery was getting low so i put this charger in and now my phone wont switch on?
The charger may not be compatible with your iPhone and the battery on your phone may be completely discharged.
Use an OEM (Apple iPhone) charger and see if it charges your phone. Do not unplug it until it is completely charged (several hours).
Dec 15, 2010 | Apple iPhone 3G
Hi my iPhone 3GS is dead. I have tried everything including charging it for 8 hours, holding the two buttons for up to 12 seconds, charge through my laptop with iTunes running and much more. When I put it...
Sounds' like your battery is defective. Bring it to the apple store. If they want to charge you for a replacement phone, try to replace the battery yourself, part is on ebay and there is a guide that shows you how at : iPhone 3GS Repair Guide
Jun 30, 2010 | Apple iPhone Smartphone
IPhone dont turn on
Keep the home and power button pressed for 10 seconds, then, leave power and keep the home button pressed...shud be able to see the charging cable logo...then restore it...
Jul 05, 2009 | Apple iPhone 3G
AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
145 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
