Question about Amana ALW880WH Top Load Washer
The tub won't spin and it's smoking - Amana ALW880WH Top Load Washer
    Sergeant:
    Champion:
  • 202 Answers
Hi... you have a bad trany ... the smoke your getting is from the belt and the trany not turning
Posted on Mar 24, 2011
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Fridgidare washer front load won't spin & there's water in the tub. It's about 10 years old
If it's that old, you're better off buying a new unit. You'll spend about half the cost of a new one fixing it.
Jun 11, 2012 | Washing Machines
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Aug 13, 2017 | General Electric Washing Machines
Yesterday my ge wcvh626ohww washer was running through a spin cycle and I heard a (excuse my noise descriptions) thump like something broke loose, and it sounded like the drum was spinning very unusually...
I don't have experience with this particular machine but it sounds like it might be the drive belt. The following website might shed some light,... has videos. There are also sites which show parts diagrams.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-3-862537-/GE-Washer-won-t-spin-WCVH6800J1WW
Hope this helps a bit.
Mar 26, 2017 | Washing Machines
Maytag Top Load washer will spin but won't agitate
sounds like the coupler between the transmission and tub is broken or slipping
Aug 28, 2009 | Maytag LAT2600A Top Load Washer
My washer turn on but won,t spin
tub bearings may be frozen up. Can you move tub by hand?
Jul 20, 2009 | GE WPGT9360EPL Top Load Washer
Kenmore 94802 washer belt overheats, smokes, and melts
sounds like perhaps the trannsmission has locked up and is not spinning freely, therfore the belt is meeting resistance and not turniing.( try turning the trans. pullley( where the bsck of belt is wound)does it turn freely??? try turning the tub from inside does it spin at all??? before i condemn the tranny i would check for article of clothing fallling between the tubs, holding from spinning, also ive seen (nails/screws/bra underwires,etc..) poke through onr of the holes with in the tub abd stuck to the outer tub also preventing the tub from spinning, look closely to all the inner basket holes!!!
Apr 08, 2008 | Kenmore 94802 Front Load Stacked Washer /...
Smoking washer
once you get the front panel off check the drain pump while your in there right now get a flashlight and look very closely at the holes in the tub for something like a nail or screwhead or something small enough to have slipped down in one of the holes of the inner tub and be jamming it now when you check the drin pump be warned there will be water still in the pump and tub so put down a bunch of towels
Mar 30, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Amana ALW880WH Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
