Question about Vacuums
Have water ace 1/2 HP sump pump does not always shut off. Can I fix this?
    Master:
  • 403 Answers
Float switch might be no good, I would start with that
Posted on Mar 24, 2011
What would cause my shop vac series90pn to quit working while picking up water
The best thing for a basement that is vulnerable to flooding is a small sump with a permanently wired automatic submersible pump in it. Such pumps are relatively cheap and available in many qualities.
While such an installation will not keep a basement dry it will ensure the water level rises only enough for the majority to flow into the sump and be pumped away without you needing to do anything.
Wet vacs of my experience either have a float valve to prevent water ingress into the motor or a switch to cut off the power if the level rises too high.
Many such vacs have a powerful motor generating much heat and are only suitable for fairly short duty cycles. When used continuously the internal heat build up can distort plastic and melt thermal safety fuses.
It is impossible to guess what the trouble might be and that will only be revealed by checking. With vacs the first suspect is the power cord and the second is the switch...
Jun 26, 2014 | Shop Vac Vacuums
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Pentax water pump 1/2 hp when pump starts works well but pump does not cut out when all taps in the house are closed
it sounds like the switch is faulty take it back to the shop and tell them ok
Mar 28, 2011 | Vacuums
Bissel pro heat wont dispense any water
these pumps always fail. try to replace the pump. also check for clogs in the spray nozzles and tubes
Feb 26, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Shark stopped steaming how to fix this
It may be mineral deposits. Empty reservoir of water, add 1/2 cup of CLR. Let sit 1 hour. Take mop outside with a mop head on but not the cloth padding. Plug it in and start pumping the handle to prime it. I used cardboard to do this on to cushion the mop and soak up moisture. Keep pumping handle until the mineral deposits clear and full steam is coming out. When I was done, I unplugged the mop, dumped out remaining CLR, and rinsed out mop reservoir with water. Please add fresh water, plug in and steam out rest of CLR out of tube leading to mop head. Otherwise your mop will still issue out CLR steam. As always, be careful to unplug and let the unit cool down before adding or removing CLR, water or mop head. Steam can cause serious burns.
Nov 21, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
After fixing rollers not turning the water will not dispense out
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Sep 28, 2009 | Bissell 9200 Upright Vacuum
How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
Jul 08, 2009 | Shop Vac 962-16-00 Ultra Pro Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
