I purchased a rev23rf room thermostat about four years ago an installed it sdccessfully. It has worked fine until now. The temperature on the display seems to jump about. eg. it shows 19.2, then 19.8, 20.4 then 19.0 etc.all in the space of about two minutes. This would not happen before. What can I do to fix this?
    Master:
  • 403 Answers
T-stats will change on their own from +/- 1/2 degrees, sounds like your in that range
Posted on Mar 24, 2011
We installed White Rodgers 1F81-261 thermostat and Bryant Plus 80T furnace about 2 yrs ago. They worked fine, until now. We tried to set the thermostat to 70F when the room is ~66F. The thermostat...
Does the display seem a little dim? If so replace the batteries. Anything else may be a furnace issue not the thermostat. Look at the furnace and see if you can view any error codes on the circuit board
Oct 31, 2013 | White Rodgers White-Rodgers 1F85RF-275...
LG a/c not cooling
you may have freon leak, does the compressor turn on.?
Jun 02, 2013 | LG M5203L Air Conditioner
We have two Lennox garage heater units that were installed about twenty years ago and one of the units is not working properly. We noticed that the fan comes on and off , sporadically even when the...
Check out the snap discs you have 2 high leval and low leval try jumping them out 1 at a time and see if it runs then , check heat exchanger is clean and not spilt , check burners are burning blue and if they need cleaning out ,
Jan 24, 2013 | Star Enerco Heat HSU45 Garage Heater 45000...
Honewell RTH 7500 Temp Sensor Problem?
Check your installer configuration. If you have it set up, in the configuration, to match your system, and you can turn it up by 5 degrees with no heat, it may be a fault at the tstat. If and when it fails to cycle on, you can jump R to W, by touching those 2 terminal/wires together, and it should begin the heat process. If it don't, then it's not your tstat. Hope this helps!
Mar 12, 2017 | Heating & Cooling
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
Heater won't start error code 11
I had the same problem and the heater started working after I cleaned both filters, the bigger one that can easily be taken off and the smaller one that needs to be screwed off.
Jun 15, 2008 | Rinnai Heating & Cooling
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
