Question about IBM Bladecenter S Raid Sas Module - - 43W3584 Storage Controller
BladeCenter S error on I/O Module 3 - 4 - SAS RAID CONTROLLER
A disk read error has occurred when booting a Dell PowerEdge 2950. Passes all diagnostics. Will run chkdsk from CD. Raid battery was degraded at last reboot but all disks showed to be fine. Raid 1
what OS?
what disk?
no raid card stated, no array stated, no type of array stated.
One can put 100s of RAID cards in this server.
both raid cards or HBA cards,(forJBOD)
i can fix any server, but first need to know what is in the box first
you meant the boot disk has errors, right,? boot.
that would tell me the disk IS BAD.
but if and ARRAY , that means you must run SMART tests
on the disks, 1 by 1 to find the bad disk.
if smart shows its bad, or weak its for sure BAD.
on real servers. the server sends you email, (set up right)
telling you disk 3 in a RAID 6 is bad, replace it now.
are you running hardware or software raid, or HBA or
fake raid cards, (4 classes there.!)
the base system new has.
4 port SAS 5/i integrated SAS controller (no RAID_
and optional, from DELL , news.
Optional PERC 5/i integrated SAS/SATA daughtercard controller with 256MB cache,
PERC 4e/DC, PERC 5/e adapter
or any of 1000s of other aftermarket cards there.
I run LSI 9361s (with MSM appl loaded)
this card will tell you what disk failed every time no kidding.
so will the PERCs setup correctly
the PERCs and my LSI and my HP raids
all have installed monitors for the RAID ,a program that runs full time all the time, and reports errors , many ways,
did you load that first and use it? seems not.
as no mention of SMART at all.
good luck.
Im not sure the names on DELL , MSM like software.
ah its OSA
never run a PERC lacking this APP. or you can not keep the server on line,.
http://www.dell.com/support/search/us/en/04#q=Dell%20OpenManage%20Server%20Administrator&sort=relevancy&f:langFacet=[en]
Mar 05, 2018 | Dell Computers & Internet
How do I make RAID 1 HDD's appear on Bootable USB WinXP Install?
a waste of time and effort installing win xp on anything as it is no longer supported by Microsoft and had real problems with drivers for just about everything
install win 10 and it will work
Feb 28, 2018 | Dell POWEREDGE 1950 Server
Can not setup RAID 1 on an IBM X3200 M3 Server
you can access the raid controller using the BIOS and system devices>>> refresh>>> then select the controller then create your raid...
don't know why they move out from the POST the controller its really stupid''' Sorry..
Feb 04, 2012 | IBM System x3200 M3 7328 Server tower ...
I have a Smart Array 431 RAID controller out of an old Compaq server. I cannot find any documentation on the card that describes the pin headers and their functions. There are 5 headers on the board: E1,...
Find below the controller components for Identification purpose.
1.Port E1
2.PORT E2
The Port E1 and E2 connectors is made up of single mini SAS HD connector which can take two mini SAS Hard disk or single SAS Hard disk while the cache module connects to a capacitor pack and cache module connects to a battery
-SAS HD receptacle connector, which can
accept either two Mini
-SAS HD 4x plug connectors or a single Mini
-SAS HD 8
x plug connector.
**The 2 GiB cache module connects to a capacitor pack. The 4 GiB cache module connects to a battery pack
3.CACHE MODULE
4.Battery /capacitor pack cable connector
Jan 04, 2018 | Compaq Computers & Internet
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
IBM Bladecenter S Raid Sas Module -  - 43W3584  Storage Controller Logo
171 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
