Question about Vinpower Digital Sharkcopier 1 to 11 Dvd / Cd Duplicator 20x with 160 Gb Hard Drive Burner
I have the Vin Power Digital 14 tray tower, and I'm getting the error 'access hardrive error'. Do I need to re-format the hardrive?
Trying to play music but get format error
Format error for one song on mp3 player - MP3 Players - Audio ...
www.tomsguide.com/forum/59577-6-format-error-song-player
Mar 14, 2012 - 4 posts - ‎3 authors
One song that I want to play on my mp3 player keep coming up "Format Error". Why is ... You can't, unless you find out WHAT format it is, and install a player that is compatible with THAT format. Apparently, you are trying to play a file that IS NOT MP3. m. 0 ... #2 doesn't really happen often, but it can happen.
Jan 17, 2016 | Audio Players & Recorders
I have a dvd+r stuck in my delldesktop tower
shutdown the computer. There should be a small hole (tiny pinhole) on the front panel of the DVD player. Unravel a paper clip and insert it into the hole. Keep pressing and it will manually eject the DVD player tray. Hopefully you'll be able to get access to the DVD and remove it.
Jan 09, 2013 | Dell Computers & Internet
My emachine tower won't turn on . I try un plugging it and plugging back and it doesn't work. Could it be that there something wrong with the motherboard or the hardrive?
> won't turn on
Remove the side-panel, and then press the ON button.
Do any fans start to turn? Feel any air coming out of the back of the power-supply?
Does pressing the button open/close the CD/DVD tray?
If not, then your power-supply has "blown", and must be replaced.
If the fans do turn, and the tray opens, but nothing happens on the screen,
e.g., no "splash" screen, nor any brief white-text "hardware-summary" appears,
then it's either the CPU or the motherboard which is the problem.
If you see the "splash" screen, or that "summary" screen, but Windows does not start to load, then the disk-drive either is not getting any power, or its "data" cable is not connected, or the disk-drive itself has "died".
It's time to take it to a qualified technician, for professional trouble-shooting.
Feb 01, 2011 | Computers & Internet
Trying to format the hard drive but can not find device drivers or partitions
If you have access to another computer, download Gparted BootDisk
This will boot on any system and allow the format assuming the hard drive is actually working
Oct 12, 2009 | Computers & Internet
Pvr is locked on 1 channel as if it is frozen.
hard disk is nackered - had same problem. if you take power cable out of hard disk it will work as just freeview box. tried replacing my hardrive but it does not like drive and freezes again - software problem or format?
Jan 14, 2009 | Samsung HDTV Digital Terrestrial Receiver
My gigabeat f60/f20 sytem error
Your hardrive maybe faulty is it clicking??? otherwise format it and reinstall the software.
Here:
http://www.megaupload.com/?d=GTC188NU
Jul 07, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Help
try to format the hardrive in the ps3 system if you cannot access the option in the ps3 in formatting your hardrive you can remove the harddrive from your ps3 and connect it on the PC and format it there
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
ERROR WITH HARDRIVE
Hit the power button. By "Hit" i mean switch it off at the back of the machine and turn it back on again. If your hard drive still gives errors, try formatting it.
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
Formatting my WD external hardrive
Hi, In computer terms, formatting a hardrive is the process of preparing/setting the different areas (for read/write) of the harddrive and keeping a list of the addresses. This way the computer would know what data went with what and to where in the HD. Most if not all new HDs are not formatted (prepared) for computer use but are detectable by the PC. Formatting not only makes the HD recognizable, it is now usable. By formatting, the PC also erases any and all references to the existing data on the HD. After being erased and prepared, it also checked for any possible errors. Hope this be of some idea/help. Good luck and kind regards.
Sep 10, 2007 | Western Digital My Book Essential Edition...
Vinpower Digital  Sharkcopier 1 to 11 Dvd / Cd Duplicator 20x  with 160 Gb Hard Drive Burner Logo
35 people viewed this question
Top Vinpower Computers & Internet Experts
jhnolson
solver2010
Are you a Vinpower Computer and Internet Expert? Answer questions, earn points and help others
