Question about 2wire Wireless-G 802.11g ADSL Gateway
When I configure my 2Wire 2701HG-T and try to come into Management and Diagnostic Console by entering in a browser gateway.2wire.net/management it required the password. How to get it?
    Master:
  • 344 Answers
Look on the bottom of the device. It should be there.
Posted on Mar 24, 2011
Where do i put my activation code
You have to connect to your 2Wire box through a web browser (gateway.2wire.net) And once you're inside the configuration page of the 2Wire, you should see the "key code page" to enter your activation key code.
Feb 15, 2013 | 2wire (1000-400108-001) Router
Unable to connect to home ATT 2wire with new Belkin USB wireless
AT&T 2Wire routers function as both routers and modems. You can disable the router functionality by placing the router in bridge mode. In bridge mode, the 2Wire device functions only as a modem and forwards all incoming traffic to the device behind the 2Wire router. For example, you can use a different router instead of the 2Wire's built-in router by enabling bridging mode -- the router behind the 2Wire device will get the external IP address, and the 2Wire router won't interfere.
Step 1Type "Homeportal/management" (without quotes) into your Web browser's address bar and press "Enter" to access the Management page in the 2Wire router's Web interface.
Step 2Provide your 2Wire router's custom password, if you set one. The router comes with no password set.
Step 3Click "Configure" under Broadband on the Management page.
Step 4Type a period (".") into the "Disable PVC Search" box.
Step 5Set the value of the "VPI" box to "0" and the value of the "VCI" box to "35".
Step 6Set the "Connection Type" to "Direct IP" and click "Submit."
Step 7Click the "Configure Services" link on the Management page.
Step 8Uncheck "Enable Routing" and click "Submit."
Jan 31, 2013 | Computers & Internet
Hi i want to chang my net password how to chang?
Hello
I got the information from the user manual on page 31:
http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf
Open a Web browser and access the 2Wire gateway user interface by entering
http://gateway.2Wire.net.
Click the Home Network tab.
Click the Wireless Settings link to open the Configure the Wireless Network page.
On the Wireless Security section select custom key ,enter new key and then click on Save at the bottom of the page.
By the way the default /current password is underneath the router.
hope this helps
Feb 17, 2012 | 2wire (2701HG-B) Wireless Router
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
How many pc's can a 2wire gateway 2701hg-b
generally 4 at a time, but I don't know if there's really a limit, but you'll be sharing your bandwidth, which will slow down your connections.
To find out, open the prompt window and type the following:
ipconfig /all (notice the space) - hit enter.
Find the Default Gateway IP address.
Open Internet Explorer, and type the IP address above into the browser field for going to web pages. You will now be able to check the router yourself.
The ip may be something like: 192.168.2.1 - check it out.
Feb 13, 2010 | 2wire 2700HG-B Router (2700HGB)
I dont know crouter configuration
Hai,
Look at your computer's IP configuration. Go to Network and Dial-up Connections, RIGHT CLICK on your network and pick PROPERTIES. Click on the Internet TCP/IP protocol, then click on the PROPERTIES button. Make sure that your settings are OBTAIN IP ADDRESS AUTOMATICALLY.
Then get into your status screen and look at the GATEWAY address. Is that 192.168.0.1 ?
(If you are using Windows 95/98/ME, then go to RUN and go to WINIPCFG)
You can also use the COMMAND PROMPT and type IPCONFIG and it will show the Gateway address. If the Gateway address is slightly different, then try to get into it at that address.
Also from the COMMAND PROMPT, (or MS-DOS window) you can use the PING command. Just type PING 192.168.0.1. If your router responds, you might be OK.
Look at the lights on your ethernet card. Is it GREEN, or does it show YELLOW.
Try rebooting your computer and using PING again.
Then the problem presist it's possible that this Router is NO GOOD.
Hope this Helped!
Aug 27, 2009 | Computers & Internet
I have a xbox 360 that fails the mtu portion of the network connection. i have at&t dsl that is run through the phone jack to the router ( 2wire 2701hg-b) and from the router to the xbox. what do you...
check on the MTU settings of ur 2wire.
This are the steps to see what ur MTU setting is:
>connect a computer to the 2wire
>open Internet Explorer, Safari or Firefox
>enter this on the address bar: gateway.2wire.net/management
>enter ur system password (in case u forget this, click on i forgot my password to get a hint)
>look for Advance in the column on the left
>click on configure services
>on the bottom, u shud see the MTU number
** i searched online and accdg to xbox tech support, ur MTU should be in the range of 1364 to 1500 **
>click on submit after u change the setting
just in case youve entered the correct MTU setting but it still does not work, u might need to contact either xbox or ur internet service provider.
Keep me posted on this one.
Dec 24, 2008 | 2wire 2700HG-B Router (2700HGB)
Fix this thing before my 20 oz estwing does......
Below are some links you can check out and see if it would help you make the gaming console connect to the net behind a 2wire adsl gateway.
Nintendo Wii behind a firewall/router:
Port Forwarding on a 2wire gateway:
Nov 06, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
I have a 2wire 2701HG-B
gateway.2wire.net... try that, it should work
Dec 19, 2007 | 2wire 2700HG-B Router (2700HGB)
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
141 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
