Question about Maytag MMV5156AAS Microwave Oven
How high should the bottom of a maytag mmv5156aas be off the floor
    Brigadier General:
  • 8,909 Answers
I would say at a reasonable safe height. There is no requirement by the machine governing that measurement.
Posted on Mar 24, 2011
Need to replace the glass turn table for Maytag Model MMV5156AAS
The part number for a replacement carousel tray for the model number you have listed is: AP3038395 and can be ordered at appliancepartspros.com. The tray is listed as item 14 under the "Internal Controls" parts list. Some other sites you might try for cost comparison:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope this helps you.
Apr 12, 2011 | Maytag MMV5156AAS Microwave Oven
When i start my microwave it runs for a few seconds then blows the circuit breaker.
You perhaps have too many large appliances running on one particular circuit. Try unplugging everything you aren't using (coffee maker, toaster, etc) and if that doesn't work, I would suggest contacting an electrician to evaluate the circuits in your kitchen. You could also replace high wattage appliances for smaller ones, say a 750W microwave,
Mar 05, 2011 | Maytag MMV5156AAS Microwave Oven
Our microwave unit (Maytag MMV5156AAS) is making a louder than normal noise (fan/motor) and is not heating. Looking for some assistance/guidance.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 02, 2011 | Maytag MMV5156AAS Microwave Oven
How is the capacitor connected to the magnetron, the diode and the trasnformer in a Maytag microwave - MMV5156AA
The magnetron is a tube with a heater/cathode element in the middle of a series of scallop-like grooves that surround the cathode, but spaced away from the cathode. A small, insulated wire protrudes into one of the scallops and extracts the microwave energy that passes down the wave-guide, past a fan-like device called a stirrer that scatters the energy just before entering the cooking cavity.The magnetron requires a low voltage/high current AC heater supply plus a 3000 to 5000 volt DC supply that is hooked to the cathode of the magnetron. The transformer supplies both voltages as AC waveforms. The diode makes the HV AC supply into HV DC by passing current in one direction only and the capacitor stores/smooths that HV DC into relatively stable DC for connection to the cathode of the magnetron. The other side of the DC supply is tied to case ground as is the outer case of the magnetron. This arrangement is typical of all microwave ovens (and radars).
Oct 29, 2009 | Maytag MMV5156AAS Microwave Oven
Maytag mmv5156aas:The button overlay melted. How do I obtain one
your part number is 53001039.
Here is the picture
and it is in stock here (use coupon "New10" for 10% off)
As far as I can tell you need to remove the grille on top to get to the screw on top of the control panel/overlay assembly. The grille is usually held by 3 screws on top or in front of the grille.
Oct 20, 2009 | Maytag MMV5156AAS Microwave Oven
NEED A MANUEL FOR THIS MICROWAVE MODEL# MMV5156AAS
Go to managemyhome.com and click on the "Manuals" link at the top of the page. Enter your model number and your manuals are available in a .pdf (Adobe) format. You can download a copy or print for FREE. I hope this helps you.
Sep 04, 2009 | Maytag MMV5156AAS Microwave Oven
Does not heat
Chances are you have a shorted high voltage rectifier diode or a failed magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 15, 2008 | Maytag MMV5156AAS Microwave Oven
Where to get parts
The roller ring is Maytag part # 53001024. Check with www.microwaveglasstrays.com or call them toll free 1-877-894-0035.
The part is in stock at a cost of $16.40 plus shipping.
Jul 18, 2008 | Maytag MMV5156AAS Microwave Oven
Maytag mmv5156aas microwave
That's a classic sign of a bad turntable motor.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | Maytag MMV5156AAS Microwave Oven
Intermittant heating
You probably have a new unit by now. The Magnetron part inside usually is the problem with this Maytag unit.I have had this unit blow the 'Magnetron' four times ! Everything else works fine. After watching the technician, I replaced it myself the other 3 times. The whole unit has to come out of the wall to do this. This High Voltage part is dangerous. The part costs about $100.00 from an online parts store. Partselect.com- or someone else.
Jan 05, 2008 | Maytag MMV5156AAS Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
