Question about JVC SR-DVM700 DVD Recorder/HDD Recorder
How to erase part of a dv before dubbing - JVC SR-DVM700 DVD Recorder/HDD Recorder
    Master:
  • 403 Answers
If its part of the original recording you cant
Posted on Mar 24, 2011
Panasonic pv-gs15 will not play back recorded video in the mini dv deck. all i see is a blue screen with red text ''picture'' on bottom right corner of the screen
Make sure your tape tab is open. See if this works. Sometimes the tab should be closed to prevent eraser or recording over existing film but sometimes the tape tab has to be open to allow for playback or dubbing?
May 28, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
Hello, when dubbing from DV mini tape to HDD
well one solution may be the speed you are recording at. L.P. recording on a dvd often creates this problem. but usually it is when you copy dvd to dvd, not mini dvd to dvd
Never record more than 2 hrs on a disk
there are programs for a work around that reprocess the dvd vob file with adjustments for the sync.
could also be a hardware problem
is your mini dv long play source as well?
Cheers
Dave
May 18, 2010 | JVC SR-DVM700 DVD Recorder/HDD Recorder
My screen is striped blue during playback with no soud panasonic palmcorder pv gs15
Your tape has a small latch on it that closes to protect from recording or eraser and opens to allow for playing or dubbing. Slide it open and see what happens.
Sep 25, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Dubbing to DVD not working
make sure the DVD is formated.
Feb 01, 2008 | JVC SR-DVM70 DVD Recorder
DV terminal
This terminal allows for direct digital transfers to other equipment with DV input terminals, such as JVC's GV-DT1 multimedia printer or the video capture card in your computer. The same terminal when bi-directional ( in and out ) allows dubbing from another DV source.
Sep 14, 2005 | JVC GR-D70EK Mini DV Digital Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC SR-DVM700 DVD Recorder/HDD Recorder Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
