Question about HP vs19 19" LCD Monitor
My monitor stays on but gives a greenish color.its an Hp 19" LCD Monitor. Itried to change the VGA cable and Display drivers but the problem persists. thnks Ronald
  • 11,361 Answers
Does it do the same when using it with another PC?
Posted on Mar 24, 2011
Red cable crt
Sometimes certain pins are missed or added more.
Or some pin connection are bad.
Try this.
Use VGA to DVI adapter from laptop and see what happes.
Jun 21, 2013 | HP L1910 19 inch LCD Monitor
Monitor displays "no signal" when powered on.
If it has the standard VGA cable just go to your local electronics store and purchase a new VGA cable and all should be fine. I would take the old cable with you that way you are replacing the cable with the exact same type of cable.
Mar 21, 2011 | Envision 19" Widescreen Flat Panel LCD...
The color is "off" on
ladywoman197, 2 things for you to do. 1. disconnect-reconnect vga cable a few times from the DB15 vga port on the pc. If problem (pink hue) persists then try here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-blackout-solution/ Your unit may need some new capacitors installed on the power supply printed circuit board. Read fixya profiles of "budmrtn" "12fixlouie" and also visit youtube for video clips of lcd monitor repair. Do the vga cable thing first!!! Could also be vga graphics card inside pc not making good contact with monitor cable. 12fixlouie
Nov 08, 2010 | HP W2007 LCD Monitor
My monitor has turned a greenish color
It's probably the video-adapter on your computer that has a problem, or maybe it's the video-cable that either is damaged, or the cable is not tightly-connected to both the monitor and to the VGA port on your computer.
Connect the monitor to a different computer, to see if the problem "follows" the monitor.
Connect a different monitor to your computer, to see if the problem "stays" with your computer.
Oct 21, 2010 | HP w1907 LCD Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Aug 15, 2009 | Acer AL1916W 19" LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Discolouring of monitor
There are several reasons for this most likely is the vga cable from the video port has undergone stress (sharp bending or crushing) this damages the cables inside and causes one or more of the colors to not display, usually red and or blue. odd it seems the green always is left unharmed when I see this...weird.
If you can I would replace the cable from the monitor to the computer. if the cable is sealed in then you may be able to find a replacement at a service center. and they could replace it for you
Apr 30, 2008 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
HP vs19 19" LCD Monitor Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
