Question about HP LaserJet 4700 Printer
I keep getting a 49.3048 error on my printer. It says to turn off and back on. This does not work.
  • tfloyd71 Mar 24, 2011
    Thank you
  • HP Master
  • 1,915 Answers
Unplug any network or usb cables and restart. If printer starts then you need to clear all jobs in print queue and then reconnect USB or Ethernet cable. This should allow printer to stay at ready. Go to HP.com and download the current firmware for this printer and follow the install instructions included. This is a common error, particularily if you are printing from newer versions of Adobe.
Posted on Mar 24, 2011
Hello
HP site update firmware in not available please help
Posted on Mar 30, 2011
frcs68
  • 1605 Answers
SOURCE: LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Posted on Dec 05, 2008
  • 10 Answers
SOURCE: 49.FF09 SERVICE ERROR
Go to http: www.hp.com/support/
lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click
Download Drivers and Software.
Check for the latest firmware image
version at the bottom of the page. If
this firmware image is newer than the
one installed on the printer and the
printer can receive a firmware update,
download the newer firmware
upgrade.
if this fix does not work try removing memory from machine turn machine on see if issue perssist turn machine off replace memory one piece at a time (if you have more than one installed) testing printer each time if you put in one stick and it works then you put in the second and it doesnt the second stick would be the problem piece.. but usually on this machine upgrading the firmware will solve this issue.
Posted on Oct 22, 2008
  • 82 Answers
SOURCE: 49.ff95 service error
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
Posted on Dec 08, 2009
indus3
  • 212 Answers
SOURCE: I get an error in HP LaserJet 4345 MFP printer,
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Posted on Apr 21, 2010
  • 52 Answers
SOURCE: My hp laserjet P2055d printer
turn printer off cacel first job in print que power on if problem continues could be formatter
Posted on Jul 29, 2010
Error e51
All four LED's flashing together indicate an error that cannot be cleared by an end user. Normally a service call will be required.
I would recommend getting in touch with Brother or a printer technician.
Mar 26, 2013 | Brother HL 5250DN Laser Printer
Keep having three problems !. Ink system failure oxc19a0035 2. Improper shut down message and printer keeps turning off and on. 3. Can not connect wireless as I had before.
Remove the Cartridges, Clean the Contact Points
Install the Cartridges back. the error should go off.
If the Issue still persist, Disconnect the power Cord from back of printer, Press and hold the OK and CANCEL button and connect the cord back.
You are not able to connect the printer wireless due to this Error on Printer Screen.
Probably.. this could be Hardware Issue if you still get this Error
Jun 24, 2010 | HP Photosmart C6100 All-In-One Printer
I keep getting a 50.2 fuser error. Turned off
wheb i give the print out, just show error 50.2 fuser error,
pls give me solution what may problems
May 02, 2010 | HP LaserJet 2840 All-In-One Printer
Printer cartridge error #1203
Try this may work
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Apr 20, 2010 | Dell 924 All-in-One InkJet Printer
HP 5610-Keep Getting: "Cartridge Error"
  1. My HP5610 was acting up with the error in cartridge thiny.
    I held down the # and the 3 and reset the unit and it is back
    in business.
  2. Is there any other error messages? Like carriage jam or something? If there are no other error then try to do a partial reset on your printer, to do that follow these steps:
    Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE.
  3. But before throwing away the (supposed broken) HP5610 I made the last attempt: I gave it the power with the new power supply and...surprise, the printer worked perfectly!!
Feb 22, 2010 | HP Officejet 5610 All-In-One InkJet...
I keep getting error 5C10 and can not print anything. Have turned it off and on and still doesn't work.
Jan 05, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Error message 0xc 180001
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on.
If it then turns itself off again, turn it back on; it should start the calibration sequence (it takes about 5 minutes) and when it finishes, you should have a working printer again!
Apr 24, 2009 | HP Photosmart C3180 All-In-One InkJet...
Error Code
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
May 27, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer error message
we still cant get it to print!!!!!!~ what is the matter!!!!!
Feb 25, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
HP LaserJet 4700 Printer Logo
5,984 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
