Support software TPM51E 2.04 for tv 32PFL3605H/12
    Brigadier General:
  • 8,909 Answers
If you need to install drivers/software.
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Posted on Mar 24, 2011
I have a Sony TV model KDL-32EX720. I need to get another main board for my TV. The main board number is: A1814571B A person I contacted says he has the same exact board number, but it was pulled from a...
dear
when we replace main board or panel in these modals software must up date other wise green and umber light blinked
please up date the software
thanks
M Nasir
Jul 22, 2018 | Sony Televison & Video
After the most recent software upgrade my under 12 month old Sony KDL75W850C Smart TV will no longer program our National Broadcasters 7 operating channels, not even recognising them as existing.
Signal strength of those seven channels may be below detection level. In this area, channels 3, 6, and 23 are consistently MIA no matter how often scanned.
Aug 14, 2016 | Sony Televison & Video
Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Jan 10, 2016 | Televison & Video
We have an audiosonic TD2401 24" TV/DVD combo for caravan & cannot get to work off solar battery. Is tv compatible for this?
if the voltage for the tv is mains voltage then you will need an inverter to bring the power up the mains voltage for the tv
if it is 12 volts unit then check that the battery is set at 12 volts or the switch on the tv is set for 12 volts.
Mar 29, 2015 | Televison & Video
Why doesn't the screen show the picture on the menu screen
This is the first generation of Apple TV.
It's getting rather old in it's specifications.
When was the last update software installed?
I received a software update for my recent model about 23 Oct.
If it's not getting updates to it's IOS then it may be too old to be compatible with iTunes 12. Technology moves forward.
Hold off for a possible future model or get the current model & use the old around the house on another TV.
Oct 09, 2014 | Apple TV MB189LL/A 160GB RTL 160 GB USB...
Dropping frames during capture with Studio 12 Ultimate for Windows Vista
Hello , rozkr
This means the video quality settings are to high for your machine .
Reduce quality . Issue should be solved but image will be less sharp .
Best results for capturing video movies or tv programs are obtained with a stand alone DVD or Blu Ray recorder .
Regards ,
fanaudi
Mar 13, 2011 | Pinnacle Studio Plus 12 for PC
TV randomly turns itself off and on
This issue is related to the TV's main board not seeing constant A/C power to unit so the board is turning off the TV.
When the TV's main board see A/C power back to the unit, the TV will try to turn back on.
This issue could be a loose power connection for the TV or a failing part inside the TV. Do other electrical devices work when plugged into the same wall outlet?
Try the following:
1. Remove the cord from the back of the TV and reinstall it (perhaps it's loose going into the TV and was not installed correctly).
2. Try putting the cord into a different wall outlet (perhaps it's not a good outlet).
3. Try using a new power cord for the TV. (Any matching cord will work for testing)
If the above did not resolve the issue, then it could be the switch mode power supply and or the main board inside the TV. Both items are easy to change out.
I can look up the LG part number for you.
Feb 16, 2010 | LG 22LG30 22 in. LCD HDTV
Televison & Video Logo
512 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
