Question about Kodak 4200 Slide Projector
We moved and discovered in a bedroom closet our old Kodak carousel 600 slide projector. It is very clean, in original plastic and box. Excited, we put on one of the several trays to view. After viewing a few slides it started to smoke. My husband turned it to fan position and we realized the fan was not moving, thus it wasn't cooling off. Thus we shut it off. Can this be repaired? Is it a belt, because when we removed the bottom we can see very minute pieces of a soft black plastic type material. okhoksch
  • Karla Hoksch Mar 24, 2011
    Can you send us on the road to trying to find the fuse? Does this fuse control the fan? We do not know where to go to find this fuse. Do you think there would be compatibility with another type of fuse? I will wait until my husband returns home and takes the fuse out and will at that time see what he thinks also. Thanks okhoksch
    Just talked to my husband and he didn't think it could run without the fuse. Does it need the fuse to run the fan? the motor runs but the fan does not move at all. Thanks okhoksch
  • 844 Answers
Welcome to FixYa!
Kodak Carousel 600 Slide Projector, wow! If I'm not mistaken, this was first manufactured around 1964.
Posted on Mar 24, 2011
  • Jas Barinaga
    Jas Barinaga Mar 24, 2011
    The most common problem with this kind of projector is overheating of it's thermal fuse.
    This is often caused by high operating temperature or abnormal electrical current surges.
    We can repair it by replacing the thermal fuse, if it is still available. It's difficult to find the replacement parts of your projector except for it's Bulb and Slide Tray. This product has been discontinued already since 2004. (Thermal Fuse Part No. 183910)
    Here's how to remove the thermal fuse:
    1. Unplug the projector from the power source and turn it upside down.
    2. Remove the screws from the base cover. (5 screws)
    3. Remove the screw holding the fuse.
    Below is an Electrical Diagram to help you pin point the location of the thermal fuse.
    Note: Sometimes there is no visible change in the appearance of a burned-out fuse.
    As of this writing, I am not able to locate where to purchase the exact thermal fuse for your projector.
    Thank you for using FixYa!
    Keep me posted.
    Jas24
  • Jas Barinaga
    You're right, the projector will not turn on if the fuse is busted. I thought it's totally dead after the smoke. My bad.
    I think there is something binding the fan or the motor or the fan-belt is broken.
    The fan-belt looks something like the picture below.
    As much as I want to walk you through in replacing this belt, you need to have the service manual as your guide since this is an old model of projector.
    The fan-belt and the service manual is available at http://www.photographicrepairs.com/kodak...
    I hope this helps.
    Jas247
Slide continuously change
The clutch contact on your KODAK Carousel 600 Projector has either burned off from use (the projector is almost 50 years old) or is out of adjustment. Either condition will allow the continuous cycle to happen. Because of the projector's age, parts will be really tough to come by. I have attached a diagram to show you what the affected parts look like. Be sure to take extreme caution - - there is exposed electrical contacts all over with the bottom cover removed. Also, be sure to remove the lamp and all optics before starting this repair.
Jan 17, 2014 | Kodak Carousel 600 Slide Projector
My kodak carousel auto focus 760 carousel does not move but the projector makes a noise when I press the buttons how can I get it to move
Your Carousel 760 Slide Projector is about 45 years old. One of the problems I have seen as Carousel Slide Projectors age is that the plastic parts in the projector get brittle and break. Given your description of the observed condition is that probably either the gear on the focus motor shaft or the gear it interfaces with (or both) that is broken. Given the age of the machine, parts will be tough to locate. Try: www.micro-tools.com
for the best chance to locate those parts. Good Luck !! Jim
Sep 07, 2013 | Kodak Carousel 4600 Slide Projector
The select bar on the projector is not working.
The Carousel 600 Projector is at least 45 years old!! Great to hear it still turns on!!
Because the 600 has no forward or reverse buttons, forward is accomplished by "tickling" (very lightly push) the Select bar. If you can cycle it forward and no Select, then you need to adjust the cycle solenoid to find the balance between forward and select. If you have NO forward, then chances are either the cycle solenoid is WAY out of adjustment, or the LINK between the CYCLE SOLENOID PLUNGER and the CYCLE LEVER is broken. You should still be able to order the LINK from: www.micro-tools.com
Good Luck !! Jim
May 19, 2013 | Kodak Carousel 600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Kodak carousel 600 slide projector thermal fuse replacement
If the FUSE is still available (this model could be as much as 50 years ago!!), the fuse is wired into the 120 volt circuit near the projection lamp. Check with: www.micro-tools.com
for availability. good Luck!! Jim
Feb 22, 2013 | Kodak Carousel 600 Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
600 wont rotate 140 slide tray
I am assuming you are referring to a Kodak Carousel 600 Slide Projector?? If so, the problem is the cycle solenoid link. The link connects the cycle solenoid to the cycle lever. It is made of plastic, and because of the age of your machine, it has gotten brittle and cracked, making moving a slide tray impossible. The bad news: If you are not VERY familiar with slide projectors and have access to a service manual, this is an extremely difficult repair. The good news: While Kodak has stopped selling repair parts, you can still buy slide projector parts from: www.micro-tools.com
My advice: Find a authorized repair dealer and have this repair done for you! Good Luck !!
Jim
Jun 01, 2012 | Kodak Carousel 5600 Slide Projector
We actually have a kodak 600 carousel projector that will not advance the slides. there is a white "arm" that doesn't move right. Is there a small screw that should be attached?
Given the age of your Carousel Slide Projector, my guess is there is a broken "link" in the slide change mechanism. This "link" is plastic, and connects the cycle solenoid to the slide change mechanism. Over time, the "link" gets brittle & breaks, giving the failure condition you describe. You should consult an Authorized Repair Dealer to see if they can still get parts for your projector, which was built between 1964 and 1972. Best of luck !!
Jun 27, 2010 | Kodak Carousel 4400 Slide Projector
I just purchased an older Kodak slide projector with a carousel on top. Everything works fine but the carousel won't advance. When you click the next button, the plastic arm that should advance the...
By the sounds of your description, your projector needs an adjustment to the slide change mechanism. This is best done by a factory-trained dealer, who has the service manual. Sorry I can't be of more help. Happy New Year!
Nov 14, 2009 | Kodak Carousel 5600 Slide Projector
Kodak 4200 Slide Projector Logo
249 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
