Question about Broderbund The Print Shop 22 Deluxe Full Version for PC
Im receiving a PMW.exe error when attempting to run Print Shop version 22 on an xp windows pc. Software previously installed on same PC and ran fine.
daryn720
  • 113 Answers
SOURCE: I am continually receiving an error message when I
have there been any operating system changes ? like moving from xp to vista ? this would be a simple upgrade if that was the case , has your product id expired ? i'd go to the manufacturers site if none of the above has changed and see if they still support the software ?
Posted on Jul 13, 2009
  • 2340 Answers
SOURCE: PRINT SHOP 22 DELUXE IS
Read this forum thread, here.
Hope it helps.
Posted on Oct 30, 2010
RescueTechLA
  • 2653 Answers
SOURCE: Will a previous file open
Yes, especially yes if it's Windows 7. Works well with older programs and 32 bit programs. Hope this info helps ;)
Posted on Dec 31, 2010
  • 1267 Answers
SOURCE: cannot install Broderbund The Print
The specifications require Xp with SP1, maqke sure you have added SP1 aqt least to your XP version.
Posted on Jan 10, 2011
SOURCE: I purchased windows 7 and
If you have some problem in running Printshop 22 in windows 7,
then download the windows xp mode for windows 7
The Xp mode can easily simulate a virtual environment of windows xp inwhich you can run any software
Posted on Feb 26, 2011
Hello, I had windows XP and now have Vista. I am
You need to run the installation in compatibility mode. This will allow the software to work virtually in a lower OS like Windows XP.
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Jun 29, 2011 | HP Computers & Internet
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
Apr 09, 2011 | Broderbund The Print Shop 22 Deluxe Full...
I purchased windows 7 and I have print shop 22 how do I upgrade it to run with windows 7?
Check with Broderbund - either it will work OK - some programmes do or you may have to buy an upgrade - when have you heard that before!!
Feb 26, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Will printshop version 22 work with windows7
Hi mfolkart,
Print Shop 22 is compatible with Windows 98 / 2000 / Me / XP
Not sure if Vista or 7 will run it.
Hope this helps...
Dec 29, 2010 | Broderbund The Print Shop 22 Deluxe Full...
I tried to install Printshop deluxe 22 on my new computer which has windows 7.it says that there is an error.what would you suggest
I suggest that you tell us EXACTLY what the error-message stated.
Or, start the Windows Program Compability Wizard, and tell Windows 7 that you want to install a Windows XP program.
Then, install the software.
Aug 22, 2010 | Broderbund The Print Shop 22 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I am continually receiving an error message when I try to open Print Shop 22 - either Windows cannot access the specified device, path or file. You may not have the appropriate permission or Could not...
Jul 12, 2009 | Broderbund The Print Shop 22 Deluxe Full...
Error: Action failed for file avgwdsvc.exe: starting service.
open services.msc from run window and then find avgwdsvc.exe. right click and select properties then check the disabled checkbox. Apply and get out of services.msc. now try to install the new version of avg.
May 16, 2009 | Computers & Internet
When attempting to install Print Artist Version 22/ Platinum Edition, I received the following message: Error 2350. FDI Server Error I tried re-installing and received the same message.
If you are using Windows XP install
windows installer 3.1
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482fc-5f56-4a38-b838-de776fd4138c&DisplayLang=en
XML Services 6.0
http://www.microsoft.com/downloads/details.aspx?familyid=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
and .NET framework 3.5
http://www.microsoft.com/downloads/details.aspx?FamilyID=333325fd-ae52-4e35-b531-508d977d32a6&DisplayLang=en
Jul 11, 2008 | Computers & Internet
Broderbund The Print Shop 22 Deluxe Full Version for PC  Logo
399 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
