Question about Husqvarna 965142201 K750 5HP 12" Gas Cut Off
Partner k750 will start but runs fast and wont idle down
    Scholar:
  • 54 Answers
My dad had a similar HUSKY "Rancher" chainsaw. They are very high revving and tempermental and require fine adjusting the two screws which are in little holes in the plastic on the side, using a small screwdriver. One screw adjusts the amount of air and the other the amount of gas or there may be a single one to adjust both. This just sets your carburator for the idle rpm. He use to cut early in the morning when the saw was still at -25 degrees Celcius and the air at +25 C, so it would ice up the carburator for a while which of course changes all the idle screw mix settings. A lot of times it is in correct adjustment but the air filter gets clogged up with fine sawdust, so you just have to clean that with some gas or carry a spare clean one into the bush. Your's is a very big displacement so it will **** in great volumes of dust while working. With a clean filter you should be able to actually stall the saw by screwing the gas in too far. When the air adjust is according to the manual, you adjust the gas one outward or CCW untill the chain starts to nudge ahead - that is the TOO MUCH GAS amount. Now turn it back in untill it reaches a happy medium or smooth tone to the engine and doesn't sound like it will conk out. You don't want the speed to be such that when you pick it up and carry it through heavy brush that it will take nothing at all on the trigger to rev up to 20,000 rpm and cut your leg right to the bone! It's against IWA rules to move a running chainsaw even one step, but best to be safe as possible. One other problem I had was an internal fuel filter inside the gas tank on the end of a short rubber tube. When it clogged with fine dust, the saw had to pull too hard to get any gas, so the fine idle adjust screws didn't work until I cleaned the inside gas filter. This was a pain as it was an older Homelite where the aluminum two part chassis had to be unscrewwed to get at the gas filter inside and then put back together with a new paper gasket, which takes hours but has to be done. If all this checks out, it may be a wrong oil-gas mix or the gas is too old. It makes quite a difference to use a very small gas can and buy just a few cups of 94% octane just for 2 cycle gas-oil mixing in these saws especially if you only use them a little and then they sit for months. Also, watch out for the bottom of the saw when you set it down on a log with 1/4" knots sticking up - these can actually break through the bottom of the aluminum gas tank near the handle underneath some HUSKYs!
Posted on Mar 24, 2011
Partner k750 HUSQVARNA
Take a look at the linkage between the throttle trigger and the carb. There should be a small screw that when turned in will increase the idle speed. This screw most often pushes on the linkage opening the throttle plate in the carb to speed up the engine.
Sep 26, 2013 | Garden
Repair manual partner k750
http://speedy.sh/A7tjW/K750.pdf This should give you the shop manual
Feb 08, 2013 | Husqvarna Partner K650, K700, K750, K950,...
Husqvarna k750 partner starts and runs fine up to limiter but will only idle for a few seconds then dies
I had a saw with a similar problem. I beleive you need a new carberator. I changed mine and my saw never ran so good. I think from all the vibration all the shafts/bushings have wore and now air is being sucked in from too many unwanted places keeping enough vacume to **** the gas out of the carb bowl.
Sep 24, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Partner k650 wont start when warm
This is a pretty common carb issue, the needle in the carb is leaking, if dirt has been throgh it then the needle seat will be worn, the only answer to this is a new carb unfortunatly.
Jul 08, 2012 | Husqvarna Partner K650, K700, K750, K950,...
I have a partner k700 was running fine ,and now no spark. any ideas
sounds like the coil went bad or the kill switch wire grounded out
Jun 03, 2012 | Husqvarna Partner K650, K700, K750, K950,...
Saw runs great then bogs down 20 sec. after i start cutting i let off it runs good then bogs again when cutting after a few sec
Check your air filter, if clean chances are your carburetor needs to be rebuilt. the carburetor has thin diapragms that get hard and won't meter the fuel in fast enough.
Jan 30, 2010 | Husqvarna 965142201 K750 5HP 12" Gas Cut...
Idles to fast
Sounds like a vaccum leak at the throttle body or the intake. check for loose lines hissing with the motor running. Had a brake booster line come loose on my 92 and it ran at about 3000 rpms.
Oct 16, 2008 | 1985 Chevrolet Cavalier
Husqvarna 965142201 K750 5HP 12" Gas Cut Off Logo
624 people viewed this question
Top Husqvarna Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Husqvarna Measuring Tool and Sensor Expert? Answer questions, earn points and help others
