Lg 14 inc tv after changin d flybak d screen goes red wiht a lot of lines across it i gets sound wen signal is connected but d croma run extreamly hot i change d picture tube but no difference pls assest
    Brigadier General:
  • 8,909 Answers
Try adjusting the A1 voltage. If that is too high that will be caused but a red screen with fly back lines sounds like the video output stage is faulty, (assuming it is the correct LOPTX).
Posted on Mar 24, 2011
My lg tv has a green tint to the screen
Sounds like a bad T-Con board which is the board at the Top-Middle of the set. I have also seen the display bad causing that problem in Lg's. Have it looked at first.
Mar 06, 2013 | LG 47LV5500 47-Inch 1080p 120Hz LED TV...
White line only, has sound, may be 14 yrs old.
Hello
If there is a white line across the screen, the vertical output section of your TV is faulty. If the line is vertical at the middle of the screen, horizontal deflection yoke doesn't get sweep signal. You haven't mentioned about the full mode number of your RCA TV. Therefore I can only give you this much hint. OK.
Mar 06, 2011 | RCA Televison & Video
Sometimes my lg 42 television has 2 thin blue & one red line from top to bottom of screen why
If the line of pixels is on the edges of your TV screen, then it is usually related to the signal feed to the TV and not the fault of the TV.
You can see thissemi-common issue with some TV antenna, Cable, and Satellite signals fed to the TV.
This will also happen if you are running a signal from one device through another device and then to the TV.
Example: Blu-Ray signal goes to the A/V amp and then over to the TV.
If the line of pixels is well away from the edge of the screen and is constant for all inputs (HDMI, Component, AVI) then this issue is the fault of at least one of the image drive boards. To trouble shoot this issue would require some TV repair tools and some knowledge of electronics.
I hope this information has helped you.
Good Luck.
May 21, 2010 | Televison & Video
Xbox 360 sound but no picture
ARE YOU PLAYING YOUR 360 ON A REGULAR TV?
Nov 08, 2008 | Microsoft Xbox 360 Console
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Tv screen goes blank with a line across middle
Hi Andy.
This is a straight forward repair & wont be expensive.
The problem is either dry joints on frame chip or component going thermal and failing at a certain temperature.
Cost for repair will be between £35.00 to £55.00 ask for a quote first.
http://dysonmanuals.inc.io/
Chris.
Dec 02, 2007 | RCA F32648 32" TV
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
