The dvd menu freezes when making selections also dvd drive makes clicking noises this player is a denon 2930ci
  • knuckles1386 Aug 03, 2008
    how do you check the laser alingment this problem occurs on most dvds not just one also I have cleaned my dvds and the machine with phillps dvd laser lens and dvd cleaner more then once to fix this
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
I suspect the problem is meaning poor firmware. Update the firmware it will fix your problem.
Thanks
Good luck
Posted on Aug 03, 2008
  • 6,487 Answers
If that's the case the lens of your player may be bad already that's why its acting this way, if your player is still under warranty better have it repair or replace from the manufacturer.
Hope that helps.......
  • 13,433 Answers
Does it do it with any disk? it would indicate a problem in the drivebay or in the lens.
Warranty? if its still covered by warranty then that will solve your problem.
  • 594 Answers
Your dvd player has a motor in it as well as a gear track to move the laser up and down the dvd to read it. what it sounds like is the motor that moves the laser accross the dvd is going out and it is only going so far down the gear track. it will cause it to freeze and that will be the clicking you are hearing is the laser trying to move farther down the track to get to where it is supposed to.... take the dvd player aprt and look for any loose or broken parts. usually when this happens a gear has come off the track or has been chewed up not allowing the dvd player to work. if you have any extra dvd player laying around than you migh be able to exchange the parts. sometime the gears in them are the same. if not you will be more acceptable to buy a new dvd player. a repair shop will charge you more than a new one costs. but it is your. I hope this helps.
  • 796 Answers
Check the position of the reading laser lens head , it might be jerked off from its position..
see whether the dvd/cd is not scratched as this could be the reason for the freeze..
Denon dvd 2500 wont play movie
The Denon DVD-2500 will not play Blu Ray disks - DVD and CD only. Make sure you're using the proper disks.
The Denon DVD 2500BT however, WILL play Blu Ray disks.
Which do you have?
Jan 14, 2015 | Denon DVD2500BT Player
Tip
How to Rip & Burn DVDs on a Mac
1) Download and install Handbrake. This free software allows you to easily rip DVDs on any Mac with OS 10.3.9 or higher. Download and install Roxio Toast to compress and burn the DVD,
2) Insert the DVD that you want to rip into the DVD drive. Close any DVD program that starts automatically. Open Handbrake.
3) Make sure that the "Detect Volume" option is selected and click the "Open" button. The Handbrake software will scan the DVD, collect all pertinent information and open the main menu.
4) Make sure that the title Handbrake selected for the DVD is correct. If it is not correct choose the appropriate one from the "Title" menu. Choose a destination for your ripped DVD in the "Destination" section of the menu, the default being your desktop.
5) Click the "Rip" button. (Do not interrupt the process or turn off your computer until the DVD is ripped.) This will create the ripped files and a folder structure which includes a "VIDEO_TS" folder.
6) Open Roxio Toast and select the "Video" tab. Select the "DVD-Video" option from the "VIDEO-TS" menu. Select the "Fit to DVD Compression" option to burn the ripped files onto a single-layer DVD.
7) Choose the "VIDEO_TS" folder that you just created by clicking on the "Select" button. Choose which options you want for your ripped DVD with the "Copy Options" button.
8) Insert a blank DVD into your DVD-R drive. Click the red "Burn" button in Roxio Toaster and allow the program to run its full course. Now your DVD is ready to watch on any DVD player.
Hope this helps.
on Sep 10, 2010 | Computers & Internet
Emerson VCR/ DVD Player Model # EWD2203 makes clicking noises when I watch dvds
OK, first go through these steps:
(if they doesn't work, then you have to say good bye to the combo.
1.) check if your DVDs aren't scratched (very common)
2.) check if your DVDs aren't dirty (eg. somebody held it in his hands after he ate a juicy marmelade bread)
3.) Try to clean the head (lens) of your DVD player with a cleaning DVD (at least 5 times).
Jul 26, 2014 | Emerson EWD2203 DVD Player/VCR
DVD cannot play English disks its a SD-16VBSB
see the steps and use the common sense. God bless you
change the region on your PC DVD player, unlocking the functionality of DVDs from other regions.
Click the "Start" Button and from the right-side options menu select "Computer." This will bring up the selectable drives menu.
  • 2 Right click the DVD you wish to unlock and select "Properties."
  • 3 Select the "Hardware" tab from the properties menu. Under "Name" you will see a list of all disk drives. Select your DVD drive from the list by single clicking the drive name. Select "Properties" from the bottom right corner of the window.
  • 4 Select the "DVD Region" tab. Select the region of the DVD you wish to play from the list of countries. Select "OK" and your DVD player will be unlocked for the region your DVD media is formatted.
  • Sep 19, 2012 | Televison & Video
    Why is the Denon S102 dvd player freezing? ... My Denon S-102 does not load CD's. No problems with DVD's and other functions.
    This is basically a problem with the optical pick up. Try wipe it with dry cotton wool. If this does not work, change the optical pick up altogether. Make sure you replace with similar part.
    Aug 08, 2011 | Denon S-102 Theater System
    I have a brand new Denon Model: AVR391 which is locking up at seemingly random times
    I have the same problem. Based upon my reading of various threads I have disconnected the HDMI cable between my DVD player and the Denon. I only run an audio connection from the DVD player to the Denon and then run HDMI from the DVD player to the TV. So far so good.
    Oct 18, 2010 | Denon Audio Players & Recorders
    My inspiron 6000 dvd makes a clicking noise. I am
    Your DvD player lens could be dirty, try to buy Cd/DvD cleaner, this could fix your problem.
    Oct 09, 2009 | Dell Inspiron 6000 8x DVD/CDRW Combo Drive...
    Hello I need firmware for denon 1740 Dvd. Cant not faind self.Thx
    Go to the Denon Global Website and select Europe, once on the Europe site go to downloads the 1740 will show up in the model drop down menu. You'll need the unit Serial Number, good luck on that, I couldn't find one anywhere on my unit.
    Next step? Buy a Sony.
    Jul 16, 2009 | Denon DVD-1740 DVD Player
    Televison & Video Logo
    98 people viewed this question
    Top Televison & Video Experts
