Question about Nikon Coolpix S3000 Digital Camera
WHEN THE CAMERA IS TURNED ON ALLASEEMS OK I CAN TAKE PHOTOS BUT WHEN I TRY TO USE THE ZOOM THE DISPLAY ON THE SCREEN SAYS LENS ERROR WITH AN EXCLAMATION MARK BELOW IT.
    Champion:
  • 226 Answers
Hi dear sir, may be dirty in lens unit or shutter fpc broken.
Posted on Mar 24, 2011
After assembly camera lcd displey is still off
Perhaps in disassembly pressure on the LCD cracked the crystal display with will cause a rich black screen. If the camera has both internal and LCD displays, perhaps the switch is set to the eyepiece? My lumix will shut off the LCD and turn on the eyepiece to save battery. Check wires to that switch.
Nov 13, 2014 | Panasonic Lumix DMC-LX3 Digital Camera
Sanyo optical 3 x zoom s70 problem of no zoom out when switch on usb connection is display when switch on card reader pictbridge cancel. when any option is selected ok, nothing happens.
Hi there the question is not much clear. But i will inform you 1st the if you connect the USB with camera you can't operate the camera for photo taking . So zoom not working. But if you mean that as normally when you try to click photo with out USB connection but that time zoom or lens not working then try to do this.
Please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 27, 2011 | Sanyo Xacti S70 Digital Camera
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Zoom error
I had sent my camera in for the same issue and they did nothing to help with it. Seems to happen when battery gets low or dies, lack of on-screen battery meter doesn't help. Typically have to manually twist the lens to close it or open it after fresh batteries installed and then seem to fix it.
Apr 08, 2008 | Fuji FinePix E550 Digital Camera
Sanyo vpc-e760 camera lens error 41
dudeee. totally have the same problem cept mine stays fully zoomed then when i try to zoom more it says lens error 41 and turns off and the lens doesnt go in
Mar 04, 2008 | Cameras
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Error-C1
Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Sep 03, 2007 | Kyocera Finecam S4 Digital Camera
Shuts off when I zoom or take photo
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Aug 25, 2007 | Fuji FinePix E500 Digital Camera
Nikon Coolpix S3000 Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
