Question about Acer Aspire 3680 Laptop
Why can't I receive e-mail through Outlook? I get error code 530 it also says password invalid
    Scholar:
  • 86 Answers
The error code that your'e getting, which is 530, means that the password for the account that is set-up on your outlook is wrong. You might need to change the password of your email account in outlook. For the instructions on how to change the password, you can search it on the internet depending on the version of outlook that you're using or you can contact the email provider that you're using for them to assist you in changing your password in outlook.
hope this helps.. regards
Posted on Sep 14, 2011
Microsoft Web Access won't send mail
If you are trying to send or receive an email in Microsoft Outlook and the password doesn't work, you can check a number of different things. Microsoft Outlook validates your email account with your email provider using various settings. Once it has validated your settings, it will send or receive email. It is not only useful to set up your email correctly but essential if you wish to use Microsoft Outlook.
Gather all of the email settings for your email account. These will be located on your email provider's website in an FAQ or support section. If in doubt contact your email provider to provide all of the settings. Look for any of the following terms: POP, SMTP, IMAP, SSL, SPA, server, and port number. Make a note of all of these. Determine when the problem exists. Check if the problem occurs when sending an email, receiving an email, or both. If the password error only happens with either sending or receiving, this narrows down the source of the problem. Click "Start," type "Outlook" and press "Enter" to open Microsoft Outlook. Click "File > Info > Account Settings." Select your email account and click "Change." Click the "Incoming mail server" field, if your error was when receiving email but not sending. Enter the full "incoming mail server" address as provided by your email provider. If your email is "IMAP" then change the "Account Type" to display "IMAP." Click "More Settings > Advanced." Make sure that the incoming server "Port" number is the same as your email provider stipulates. If your provider requires SSL, then click "This server requires an encrypted connection (SSL)." Click "OK." Click the "Outgoing mail server" field, if your error was when sending email. Enter the full outgoing server address. Click "More Settings > Advanced." Make sure the "Outgoing server" port is correctly set. If your email provider requires encryption, then select the correct type from the drop-down menu. Click "OK." Click the "password" field and make sure you have entered the correct password. If your mail provider requires "SPA," then click the "Require logon using Secure Password Authentication (SPA)" to enable it. Click "Next" and then "Finish." Your password should now work. Hope it helps.
Aug 07, 2012 | Microsoft Exchange 5.5 Outlook Web Access...
Cant recieve emails
Who is your email provided by? AT&T? Yahoo? Hotmail? Gmail?
You need to go to www.google.com and in the search box type your provider and search for the settings that should go with outlook express. For example if my email is provided through Yahoo. I would type in the search box "yahoo mail and outlook express". You will see how to configure the PoP3 and SMTP for sending and receiving mail through outlook.
Before doing all that it just seems like your problem might be that you have the wrong password in the outlook setup for PoP3. Edit your settings in Outlook and make sure you have the correct password. I think you click tools or edit when you have outlook open to get to the email accounts and edit the settings. Do this first and you can test it to see if it is working.
Apr 22, 2012 | Microsoft Outlook Express
How can I fix my error 530 problem in outlook?
Your Outlook settings work fine at home, sending/receiving mail. You're on the road now, and you can no longer send, but only receive mails. You're getting an Error 530 or Outlook error 0x800CCC78.
The problem is the on-the-road ISP may be blocking port 25, and/or your ISP might not accept mail being relayed from other network domains. SBC Yahoo allows you to change your SMTP port from 25 to 587. Most ISPs let port 587 flow through. Internet access works, receiving email works, you just can no longer send.
Solution:
  • Go to Outlook, Tools, Accounts, Server, Advanced, and change the SMTP port from 25 to 587. Hit Apply, OK, then exit/restart Outlook.
  • Start Outlook, create a test email and send it. Should work fine.
  • The solution might vary with other ISPs. Your home ISP must support an alternate port for SMTP TCP traffic, and the current ISP providing you access must not block that alternative port.
  • Recognize this is all the fault of spammers and the ISPs trying to slow them down. This is why they block port 25 for non-customers.
If this doesn't work, just change the port back to port 25.
Alternatively, as with SBC Yahoo mail, you can always use the Webmail interface. This, like all other web pages, uses port 80, which ISPs do not block.
Jul 06, 2011 | Computers & Internet
Unable to send e-mails from Outlook, Error message 530 ...
hi check the internet connection,because the isp may be block the smpt port 25,which is used for send mail in outlook,or check SMtp server is correctly cofigured.
thanks
Feb 19, 2010 | Microsoft Office Outlook 2007 for PC
Trying to setup Microsoft Office Outlook getting error 530 Send test e-mail message: Cannot send the message. Verify the e-mail address in your account properties. The server responded: 530 authentication...
the problem should get solved by going to your email account settings (Tools > Account Settings > More Settings), and checking the "My outgoing server (SMTP) requires authentication" option.
Dec 08, 2009 | HP Pavilion dv6000z Notebook
I cant send an email from outlook it keep saying 530 authentication required
This error indicates that sending mail via your mail server requires a username and password (this is not the default setting).
Check with your mail providor for the proper settings for sending e-mail.
This is a common issue and will very likely be documented on their suport web page. You did not mention which version of Outlook. If you have Outlook 2003 or even 2007, see th following tuturial and pay attention to slide 16 &17 as this is how to enable outgoing authentication.
http://www.powweb.com/support/tutorials/email-auth_outlook2003.html
Hope this helps,
-Tor
Nov 21, 2009 | Computers & Internet
E-mail on 530 dell yahoo. com mail
Need more details for the same...
Are you using MS Outlook or Outlook Express Or Windows Mail or logging on to the Mail server??
For Outlook / Windows Mail issues you can delete and recreate the account to rectify the error (Your saved mails won't be deleted).
Please give more details to help you further.
Nov 11, 2009 | Computers & Internet
When I tried to send email from Outlook, the Internet Service Provider replied -ERR [AUTH] invalid user/password. How can I correct this error?? My ISP is att.net. I have not found a solution on that...
This means that your user/password combination is wrong for that email server. So double check that you have the right password and user name entered for that account in Outlook. If you're 100% sure you have it right, then you might be using the wrong email/authentication server. If you continue to have problems and are located near Washington DC, feel free to contact me through my website.
Nov 03, 2009 | Yahoo Mail
Outlook express...hotmail My friend stopped receiving e-mails sept 1 2009. when he opens up an e-mail received before sept 1, he gets the following error message... access to the account was denied, verify...
First make sure the Internet is working.
If it is then try to login with the same username and password on www.hotmail.com if you can log in then it's a problem with outlook express if you cant then that is the problem.
To make sure outlook express is correct click on Tools, Accounts then click on Mail tab and then click on your email address and select properties make sure the username and password are correct or retype them.
Sep 25, 2009 | Dell Computers & Internet
Outlook express
0x800CCC78 SMTP_REJECTED_SENDER Unknown sender. This is caused by having the incorrect e-mail address in the Reply-To field.
You may have to authenticate in outlook express by putting in the SMTP server name of your internet provider instead of yahoo
for example
Incoming = smtp.mail.yahoo.com
Outgoing = smtp.yourISPservername
Some isp's will not let you send out with a different smtp server than theirs.
It's why you can receive but not send.
Sep 15, 2009 | E-Machines eMachines Desktop PC
Acer Aspire 3680 Laptop Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
