Question about GE Heating & Cooling
GE motor wiring to terminals in end of motor. Motor Mod 5J575CX! FR 45 Type KC 1725 RPM 3/4 HP 1 PH 115/230 V thanks John djbonnet@mts.net
the dr
  • 447 Answers
SOURCE: Furnace Blower Motor Specs
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Posted on Dec 18, 2007
burzerko
  • 254 Answers
SOURCE: HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
TheMobilian
  • 8220 Answers
SOURCE: wiring diagram?
They ain't power leads. They carry heat element current from the cent sw when the motor is running.
Posted on Jan 10, 2009
meBNme
  • 334 Answers
SOURCE: I have a Trane XE1200
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Posted on Sep 07, 2009
dmftrucker
  • 1922 Answers
SOURCE: home ac compressor fan won't turn all the time.
your looking at $175-$225 for just the single phase motor depending where you purchase, I just replaced mine(identical unit) due to screaming dry bearings, if you replace it your self make sure to keep new wires tight along side of unit or fan will cut them if loose and its a fan- 5mfd/25mfd compressor@440volt cap
Posted on Sep 27, 2009
Testimonial: "Thank you, you gave me exactly what I asked for. Now I can shop wisely. Tim"
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
How to connect a motor
It should be either on the nameplate or junction box cover.
Apr 24, 2014 | AO Smith Evaporative Cooler Motor 2 hp...
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Can't find a wiring diagram for a Delco 1/6 h.p. Mod A221-cc Elect motor
I am sorry but we have no wiring diagrams here at fixya.
Jul 27, 2012 | Cars & Trucks
Need to know what color wire coming from motor itself and where they go.....wiring diagram on side only tells leg 1 and leg two and so on, but the wires coming from the motor are not attached to those...
Thank you for posting your question here on Fixya.com.
Part of your problem will be the snake has a reversing switch so it is not as simple as just wiring two line leads. I assume you have a DPDT switch for reversing it? If so line goes to the center posts/terminals, motor L1 and L2 go to one end, motor red and black to the other end, and a jumper crisscrosses from end to end allowing the reversing.
In essence, what has to happen is in one direction motor L1 and red get power from one line and motor L2 and black from the other; to reverse motor L1 and BLACK get power from one line and motor L2 and RED the other. All of this assumes you are connecting to 115VAC since that is the portion of the diagram you reference. If not, add a comment with what you are connecting to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Dec 14, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Need a ge motor 1/3 hp 1725 rpm for a toledo commercial slicer or why does motor will not start until you spin shaft?
check motors bearings for oil ports try to lube first before replacing-common motor -appliance parts-online parts-catalog(grainger)or other hvac-plumbing-heating stores
Nov 04, 2009 | Kitchen Appliances - Others
Wiring diagram?
Jan 10, 2009 | Dryers
Heating & Cooling Logo
108 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
