I just installed lantastic 8.01 which worked fine on XP pro. With Windows 7 it installed okay, and connects okay. But when I try to access the network through windows explorer , Blue Screen crash, a coule of time instead of the crash I got the message: Invalid access to memory location. Thanks
Theknack
  • 144 Answers
SOURCE: usb network adapter error
What I recommend is to uninstall the driver and reinstall it back again.Incase the 1st solution doesn't work then you need to uninstall the other driver off first,like sound and display, and install this wirless beferore them.I think conflict with the other driver.
Best of luck,takecare
Posted on Apr 20, 2008
XRAYRON
  • 156 Answers
SOURCE: Computer not connecting to Router
Ok make sure your PC is connected to the router with a network cable for programming.
I noticed you said 192.168.1.1. I see an extra period just wanna make sure your typing it in correct
192.168.1.1
Ok so make sure the cable modem is plugged into the WAN on the router... Now connect another ethernet cable to the PC and the router. Reset the modem and router... wait a few mins and try to connect to the programming setup.
User name= admin Pass=admin
Posted on May 06, 2008
SOURCE: Fujitsu amilo d1845, Windows xp start up problems
ive just tried a new hard drive and windows xp sp3 on it and it still dose the same, even in safe mode it stops at WINDOWS\SYSTEM32\DRIVERS\MUP.SYS all the time cant get any further
Posted on Oct 27, 2008
Joed911
  • 4338 Answers
SOURCE: IRQL_NOT_LESS_OR_EQUAL
Here is a link that documents this failure and also includes a link to the driver page.
General Protection Fault (Blue Screen) May Occur With Old Adapter Drivers
http://support.intel.com/support/wireless/wlan/sb/cs-025283.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jan 11, 2009
  • 37 Answers
SOURCE: Connected with limited access
This actually sounds like the device is not getting proper DHCP settings.
First of all, power cycle the router, and reboot the computer to make sure a fresh connection from both devices is achieved.
If the issue persists, check to make sure the computer does not have any static IP settings stored in the adapter.
The following steps will tell you how to do so:
-Start
-Control Panel
-In Classic View, select network connections
or
-In Category View, select Network and Internet connections, then select network connections
- Right click the appropiate network adapter (Local Area Connection, for cabled connections, wireless for wireless connections)
- Select Properties
- in the "This connection uses the following items:" Box select the "Internet Protocol (TCP/IP)" (making sure to keep the checkbox selected (selecting the name helps) then click properties.
- If obtain an IP address automatically is selected (and the boxes below are grey), and Obtain DNS Server address automatically (again grey boxes below) are selected then something else may be happening, which will require more advanced steps.
If the boxes are not grey, then you may have incorrect settings, select the appropriate radio boxes (listed above) to make the boxes greyed out, and that may resolve your issue.
Posted on Feb 26, 2009
How do I stop Acid Pro 7 from crashing on Windows 8.1?
The only "problem" is Acid finding SampleTank 2 when I try to open projects created on xp / win7. Because it's 32bit it installed in (x86). The file path seems to be the issue (since "x86" is not in the file path on xp/7) but other IK apps open fine with xp/7 files and SampleTank 2 opens fine in new projects. if file path consistency is to be maintained a 64bit version is needed...?
RE Tips for installing Acid Pro 7 in Windows 8 1 Sony ACID Product Family...
See this webpage as Sony says it is Windows 8.1 compatible
http://www.sonycreativesoftware.com/acidpro/techspec
contact Sony support for this product.
Technical Support
Sep 04, 2014 | Microsoft Windows Vista Home Premium DVD...
I have Horoscope explorer Pro 3.0 which i have installed in widows XP and is working fine. But I am not able to install in My Windows 7.
Horo 3 is not compatible with Windows 7. If you wish to work on Windows 7 you better upgrade to Horo 5, which is available from http://itbix.com
Feb 06, 2011 | PublicSoft India Horoscope Explorer Pro
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
I installed Windows 7 Home Premium 32 bit on my laptop. Now, when it connects to wireless router, (LynkSys WRT110), it disables the router. There is a Vista Home and an XP Pro machine on the network and...
You need to setup your new homegroup settings on your Windows 7 PC. Once you set this up you can copy to all your windows XP computers. This will put all the computers in sync. You can find the homegroup by going to the start menu and searching for homegroup. Please let me know if you have questions.
Oct 23, 2009 | Microsoft Computers & Internet
CANT GET WINDOWS XP PRO TO COPY FILES TO A GX280
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
Sound for windows 7???
reinstall your XP Pro..
Feb 22, 2009 | Computers & Internet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
