Question about Roper RAS8445KQ Top Load Washer
My washer is leaking water from the bottom during operation. All of the hoses see to be connected correctly. Any answers?
  • 3 Answers
Gurl or boy jst get a new one AND STOP BEING cheap
Posted on Mar 24, 2011
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from bottom of washer a day after I've done laundry
My guess is you have a slow leak in the inlet. Probably somewhere after the valve. Try turning the valves off between washes. If that fixes it you know it's an inlet leak. There is usually a pair rubber hoses (same connectors as a garden hose) connecting the washer to the inlet valves. In order of ease/price of fixing:
  • one of the gaskets in the hoses is cracked ($0.05)
  • one of the hoses has a crack or isn't sealing properly ($10)
  • the valve outside the washer is leaking ($15 if you DIY, $150 for plumber)
  • The connector or valve in the washer is leaking ($20-$30 if you DIY, $$$ if you pay a repairman, $0 if it's under warranty)
Mar 27, 2014 | Washing Machines
Amana tandem 7300
What does it mean when a washer leaks from the bottom?
The pump will have an outlet or drain hose, an inlet from the tub and may have a circulating hose outlet as well. If you have water leaking from the washer during a wash or drain cycle, check the area of the drain pump. Look for signs of a loose hose clamp or a leaking hose connected to the pump first. Washer Repair Diagnostic Leaking Water Amana Whirlpool NFW7300WW
Jan 18, 2018 | Washing Machines
Water leaking from bottom of my WFL2860 during draining
Check the hose clamp connection on the water pump.
Aug 03, 2011 | Bosch Washing Machines
My machine is a 501 smartdrive and is not filling te bowl it is all going onto he floor instead
Hello there:
I will answer this in 2 seperate post's for you ok?
Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Sep 26, 2010 | Fisher and Paykel Washing Machines
Water leaks out of bottom of washer
The screw in the washer tub, is not a factor in this. I'm not sure what brand of machine you have, but several machines have a fill hose that connects to the outer tub of the machine. Sometimes when a machine gets loaded heavily, during the spin cycle items in the machine can actually knock the fill hose right out of the tub. Then when the machine trys to fill the next time, all the water runs down the outside of the tub and leaks out of the bottom of the machine.
Repair is to open up the machine. You'll need to remove the top cover and that will give you access to the hose/tub connection. It may be as simple as reinserting the hose back into the drum or you may need to replace it if it got too damaged and won't stay in the hole correctly.
If you need specific how to's on opening up the machine, get back to us with the make and model info and we'll be happy to help you open that washer up!
K
Aug 01, 2009 | GE Washing Machines
My gw712 washing machine no longer empty's the tub during the rinse or the spin cycle. It produces a single beep every second, I have followed the manual and I still have the same problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
My front loader is leaking water from the bottom
During fill only
All the time
During fill only
All the time
Oct 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
35 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
