Question about Samsung Televison & Video
I have an Samsung LE52B750 TV that it has horizontal lines and a double image on the right side of screen. Of course it is out of warranty. Does anyone know what this problem is?
  • 56 Answers
Hello, it sounds like one of the display boards has gone. Its probably not the screen as you wouldnt get any picture at all or very little. Even though it sounds expensive, most of the work is in dismantling the tv. These days its just a matter of replacing a board or two. Get two or more quotes and pick the best one. I hope I have helped.
Posted on Mar 24, 2011
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
I have a Samsung 50 inch 3D Plasma TV (model number PN50C7000YF) that has recently started developing black horizontal lines across the top of the screen all in a 3 inch horizontal area. Every week I get...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 15, 2014 | Samsung PN50C7000YFXZA PN50C7000 3D Plasma...
Double image in samsung lcd tv
IF it is still under warranty, take it in to be replaced.
Aug 28, 2014 | Samsung Televison & Video
Lcd vertical yellow line and Black Horizontal Line with Double Image Below
Sounds like you pulled the TV apart, good luck. Hope you earthed yourself. You could try a replacement t-con board. if that was the problem. http://electronicshelponline.blogspot.com.au/2012/06/how-to-replace-faulty-tcon-board.html
Apr 08, 2014 | Vizio Televison & Video
Samsung 52" lines and double images until tv warms up
It is a Samsung which means power supply issues.
Jan 30, 2018 | Samsung Televison & Video
Samsung LN52A850 Horziontal Lines Double Image on Right Side of Screen
Saw the video just now: looks like smearing and if pushing (don't do that) results in it clearing or changing it is either an issue with the boards(set uses two to drive the panel--(one for right and another for left in most cases) OR one of the connectors from the display panel which is the entire front screen unit has a loose or dirty connection or has come loose inside the panel there--if that then entire panel would have to be replaced and it is cheaper to replace set if the panel ends up being the problem.
Someone has to look inside and GENTLY probe to see what or where it is being caused by.
Mar 24, 2012 | Samsung LN52A850 52 in. LCD HDTV
I've had my Toshiba 46RV530U less than 2 years,
Diana, did you ever find a solution? My Toshiba (same model) is about 2 years old and it started getting these 4 horizontal lines spaced pretty far apart and a double image at bottom. When I lightly tap the top of the TV, they went away. But now that is not working. Please let me know. Thanks.
Jeff
May 15, 2010 | Toshiba REGZA 46RV530U LCD TV
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
My Sony KDL-46 Xbr4 picture flickers and there's a blinking light that continuously blinks inside the panel. What does this mean? Pete
The blinking light is a problem code.
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you blinking light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 04, 2009 | Sony Televison & Video
Televison & Video Logo
401 people viewed this question
Jerry Greenberg
Jerry Greenberg
