Question about Sharp R-820B Convection/Microwave Oven
The display on my Sharp R-820 BK convection microwave no longer displays! It flashed between the usual brightness and quite faded brightness for a few days. Now it is so dull as to be all but unreadable. The unit seems to function fine otherwise.
  • Sharp Master
  • 9,098 Answers
The service manual will aid you in disassembly. It is here.
This can be repaired for $39.95 in most cases. Details here.
Posted on Apr 29, 2011
  • Mary S Schriver
    Mary S Schriver Jan 12, 2018
    It told me everything except for how to get into the time display without disassembling the entire microwave. Any help there?
  • William Miller
    William Miller Jan 12, 2018
    You do have to disassemble the microwave to get to the display or to remove the controller assembly to send it to me for repair.
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
Replaced 20A fuse - now display blinks
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
Sharp carousel microwave convection oven keeps blowing fuse
The service manual is here:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
You can get Sharp parts from Encompass here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See this: http://031d26d.namesecurehost.com/mwd/doorsw.txt
Aug 01, 2013 | Sharp R-820BK Microwave Convection Oven,...
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
The display no longer works on my Model R303CW Sharp Microwave. Is there a part that will fix the display?? Everything else works fine.
Nope , could be dry joints or corroded pcb or defective display driver or supply ? Only can be told once opened and inspected.
May 13, 2009 | Sharp R-303CW Convection / Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Sharp Microwave R-950A
Chances are your thermistor is defective.
This UK model is probably similar to the US model R-930 or R-820.
We have both service manuals at our site and while the part numbers will not necessarily be the same, they will be handy for safety, disassembly and troubleshooting. They are here and here.
When you're ready to order parts, visit Sharp UK for spares dealers and servicers.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | Sharp R-242 Microwave Oven
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
310 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
