Question about Acer Computers & Internet
Not booting press power button (mains) laptop fan operates, hdd/power/battery lights on.accesses dvd but will not read disk, cpu fan on/off approx 3 times then switches off. at no time does anything happen on lcd. can you help!
  • bluzeman Aug 03, 2008
    Thanx but tried it with battery in and out, no difference! Removed HDD and memory and reseated them. Checked HDD in a usb enclosure with a desktop pc (scandisked) - fine - 2 patitions with data on them. removed heatsink fan & cpu reseated with compound - in for a penny in for a pound ! ! ! !
    Sergeant:
  • 395 Answers
Remove battery and try again (on mains). If it works then battery may be too far gone!
Posted on Aug 03, 2008
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
Laptop Does not Boot
your hard drive might be fried so I'd advice you to take it to a pc shop
Dec 31, 2012 | Computers & Internet
After turning on it turns off automatically after 3-4 seconds
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Jun 07, 2012 | Computers & Internet
Dell OptiPlex GX620 no boot sometimes it appears black screen with a cursor blinking
Apr 02, 2012 | Dell OptiPlex GX620 PC Desktop
Hi i have an r630 desktop and it did work but now i have no power to motherboard no fans cpu but i do have power to the hard drives and rom replaced power supply same problem
Maybe your motherboard is toast.
Mar 30, 2012 | Computers & Internet
No beeps, no video, fans working,
no the floppy disk is not faulty, it is normal and required that the floppy disk drive light blink to indicate that the drive is working. And about the power on the power button might be stuck inside that is why it keeps turning on immediately you connect to main power
Aug 03, 2010 | Intel D845PESV Motherboard
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Toshiba Satellite p305d-s8828 will not BOOT. Removed battery and tried the 20sec hold down power button -- replaced batt and power -no boot still. Removed 1 Mem module at a time -- no boot. removed Batt...
try getting into BIOS and check if the boot seq is fine or if the HDD is not recognised...
press f2/f1/home/del key etc to get into BIOS after the machine starts....
the only option is to reload OS if they machine is booting into BIOS but not loading the boot/OS files
Jan 22, 2010 | Computers & Internet
My HP Compaq Presario v2000 has new mobo, new CPU
You probably put more than a pin-head size drop of heat grease compound on CPU, thus "bleeding" over on the CPU, effectively overheating processor (very common). In any event, your problem is overheating -that's *the* place to look for now.
gurutim
Mar 18, 2009 | HP Compaq Presario V2000 Notebook
Amilo L7310GW will not boot up
Can you try switching on without the wireless mini pci card . but exercise care while disconnecting the thin two wires named MAIN & AUX from WLAN card .It is easy to remove this and you dont have to disassemble the entire notebook for this
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
55 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
