Question about Gateway FPD2185W 21 in. LCD Television
Doesn't turn on power led flashing blue then light blue then off
I would love to know how to repair this monitor. haven't tried the 8caps problem but that doesn't seem to work for everyone...maybe the error code from the power button is helpful if i watch/record it. any error code lists? Many thanks
matt Matt.radtke@gmail.com
  • 2 more comments
  • dave73 Sep 07, 2008
    i have the same problem, my moniter won't turn on, if i unplug it then plug it back in, the power button flashes a couple of times then goes off.
  • Anonymous Oct 24, 2008
    If I unplug it then plug it back in then the blue light in the power switch would about four times then stays on solid and no display on the screen and I can't turn on the power on the blue light. I would have to unplug it again and then it does the same thing over and and over again. There is this site (monitordepotusa.com) that fixes them for $98.00 plus shipping.
  • bjtera Oct 29, 2008
    I am having much the same problem. My computer is running XP and has worked fine for over 2yrs. It was working fine last night. when I tried to turn it on this morning the power button flashes at about a rate of 1-1.5 sec. if I am looking at the screen then I can see the gateway logo flash on for only a brief second and then off. I then tried to disconnect the monitor and only power it on independently to see if it would display "no signal" or go into standby. I only get the same flashing problem. I have tried hooking it up to my older computer that is also running XP and I still get the same flickering problem. One more observation is that no matter how long I leave the monitor on it will only flicker the gateway logo. This leads me to believe that it might be something with the Power Supply other wise I would see my desk top or other screens in between the flickering. Any help would be greatly helpfull.
  • bromeed Dec 26, 2008
    i have the same problem and it occured after i tried to download ubuntu
  • 903 Answers
Http://forums.nvidia.com/lofiversion/index.php?t55653.html
LOTS OF PEOPLE ARE HAVING THE SAME PROBLEM IT IS A FIRMWARE PROBLEM AND THESE MONITORS ARE NOT COMPATIBLE WITH VISTA. VISIT THE SITE TO SEE OTHER PEOPLES SOLUTIONS ETC....
Posted on Oct 25, 2008
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Camcorder wont turn on at all
Are the batteries fully charged ?
Jun 17, 2017 | Mitsuba DV777 Camcorder
VX2835wm. When plugging in to wall, screen flashes for about 2 minutes; there is no yellow no blue LED. It will not respond to on off button until it has finished the flashing routine.\r\nThen blue LED...
Hi, According to your problem, Check the adjust switches and readjust the monitor first. You have to repair the PCB of the monitor. Better if you can replace the PCB of the monitor.
Sep 02, 2011 | ViewSonic VX2835wm Monitor
When i press the power button the led light flashes but it doesn't do nothing
That could mean a lens failure. Try to hook up adapter to computer if you haven't tried new batteries. Lens failure is quite common and it is best to spend a few bucks at a camera shop instead of trying to force it to work.
May 26, 2011 | Samsung S860 Digital Camera
Sceptre x20wg 1080p monitor
In case you know very well electronics, you must open the cover of your monitor and find a fuse burned. You change this. You must repair power supply which supports voltage to work light on your screen. You must be expert to repair this.
Oct 29, 2009 | Computers & Internet
Syncmaster 225ms LCD monitor is blank with flashing blue LED. The monitor has previously worked however since last time of turning off it will not now turn on. The blue LED light flashes but there is no...
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the badparts, replace any that look like the pictues and your monitor shouldwork fine. The capacitors do need to be installed with the correct +and - connections, note the stripe on the old one and insert the new onethe same way. If you don't want to try the repair yourself we offer arepair service for $35 plus shipping. I hope this helps, if so pleaserate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 20, 2009 | Computers & Internet
Blue blinking light
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
1,340 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
