Question about Karcher Garden
Ihave a Karcher KB 4040 that has a leak at the borrom of the fitting in an inaccessible place. Could you tell me where I can take it to get it fixed
  • 10,865 Answers
Hello alex. Look in the yelllow pages for either a power washer sales shop or a plumber. If you find a plumber to do this repair ask for a firm price upfront so there are no surprises. Joe
Thanks for choosing Fixya!
Posted on Mar 24, 2011
My Karcher KB 9030 has lost pressure and is hunting when no demand water supply is plenty
In most cases the water lines can have leaks that bring bring in air and so the pressure will be less. Power off the washer and let the water flow without any air bubbles. If you seen bubbles then recheck the joints.Check the same with the outlet.
If not there is fault on the main pressure pump.
May 02, 2011 | Karcher Garden
Ihave a 1995 Ford F250 I have a heater hose hanging lose next to the radiator can you please tell me where it hooks up to I can not see a place for it
in all honesty i have never seen one of these cars in my life here in spain but i would hazard a guess and say it fits to teh front of the engine around the water pump area ,or the heater has been by passed as the core was leaking ,fill engine with plain water and see where it leaks is a good guide as to find if and where its fitted
Mar 01, 2011 | 1995 Ford F250
When connected and switched on my kb 4040 just buzzes
Sounds like the start capacitor is faulty. take out capacitor and if it is burnt replace with new one.
Jan 31, 2011 | Karcher Garden
I own a karcher KB 4040 which is about three years old. It has begun loosing pressure as a result of a leak within the motor/pump area. I'm loosing as much water via the pump as goes throught the nozzle....
England (UK)
Home & Garden Helpline: 01295 752200
Karcher USA telephone number
303.738.2400
If you call which ever country you are in telephone number they should be able to guide you to the nearest service center.
Jan 11, 2011 | Karcher Garden
My Karcher 2.36 is leaking at the inlet point can someone tell me how to fix it
This sounds like the o-ring inside the end of the high pressure hose could be damaged and is in need of replacing. If this is not the case you may need to have the inlet replaced.
Jan 09, 2011 | Karcher K2.26 Electric Power Washer
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
Hi,karcher hds hot pressure washer now pressure when you pull trigger and pulses.
what you need to do is, take the screw fitting which goes to the water tank off, then the one that goes from the water tank to the pump head .
then put the one that was in the first place going to the water tank on to the pump and force feed with water.
see if you can see water leaking from any where seals hose.
try running the machine to check the pressure.
if water leaking from pump head you need seals.
Mar 21, 2009 | Karcher Garden
Karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Karcher KB 499
Hi the pump surges when there is a leak on it find the leak that should sort your prob.
Hope this helps. Sean
Feb 17, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
71 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
