Question about Panasonic DMR-EZ28K DVD Recorder
I HAVE A PANASONIC DMR EZ28 DVD RECORDER AND IT WONT READ ANY DISC CAN YOU HELP PLEASE NOT EVEN A LENS CLEANER
  • Mark Ritsema Aug 19, 2012
    I've also had this problem. However, my laser works fine as I can record ok, read finalized discs, and read normal movie discs. My unit will make a horrible noise and then give the disc errors when I try to finalize the disc or even trying to read previous, unfinalized, recordings. It's almost unusable for recording because of this.
  • Martin Tovar
    Martin Tovar Nov 10, 2015
    i have a Panasonic DMR-EZ28, it has a no read problem... i just gave up on it, way to expensive to fix.
  • Panasonic Master
  • 508 Answers
The 'No Read' error is a classic case of a failed laser (and/or DVD drive). In many Panasonic DVD devices (recorders, players and some Blu-Ray models) the laser is part of a traverse unit or 'assembly' (a block with laser and spindle motor in one). With this unit, unless you are tech. savvy and are aware of the likely cost(s) of replacement part(s) for this type of product, you can go ahead and order from Panasonic directly - subject to shipping and tax (assuming the part is available) - this could be expensive, and you would also need the right equipment/tools and experience to do this (it is much easier to simply replace the whole DVD drive itself in the unit - just note the original drive number and connection type before seeking a new one, after that - should be a straightforward fit, save on labour costs...) - these drives are not exactly easy to repair at individual component level; hence why in most cases the whole drive is replaced when part of it fails (not impossible to replace either!).
If you aren't familiar with this sort of thing, your next best bet is to submit the recorder to an authorised Panasonic service centre, obtain a (reasonable) quote on likely repair/part(s) cost(s), along with a second opinion, then you can make a firm decision on that basis. Up to you whether you pursue it further or not. The DMR-EZ28 is not as old as the DMR-ES15 and is more reliable in general. Assuming this can be repaired, it could be very expensive, so keep that in mind, but you won't know for sure unless you get a quote from a workshop. It may also take several weeks before repair (if possible) is completed.
If all else fails, or it is probably going to be too expensive/uneconomical to fix, or you cannot get a replacement DVD drive anywhere for this model, then consider a new one - but ONLY as a last resort. The cost of replacing a disc drive in your existing unit vs. the cost of a brand new machine could be significant.
Not the best news, but certainly worth investigating - if you want to do so.
Posted on Mar 24, 2011
    This does answer my question as well. The laser in my unit works fine as it will record, however, when trying to finalize or go back and read a previous recording the unit will make a horrible noise and then give the disc errors. This would be the drive spindle then.
Have philips univerasal remote need codes for my panasonic dmr-ez28 dvd recorder
Panasonic DMR-ES30VS DVD Recorder/VCR Universal ...
www.fixya.com > ... > Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR, universal remote related issues. Getfree help ... My remote does not work anymore. what is the code for a universal remote? Thanks in ... Question about Philips DVD & Blu-Ray Players ... How do I getremote code for GE universal remote control Need remote code? How to ...
Philips Magnavox MWR20V6 DVD Recorder/VCR Remote ...
www.fixya.com > ... > Philips Magnavox MWR20V6 DVD Recorder/VCR
Dec 20, 2015 | Panasonic Televison & Video
Dvd recorder panisonic DMR-EZ28 stopped reading
try different type of DVD if nothing happened, use a disc cleaner it might be dirty. Hope this info help you.
Jun 07, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I set my DMR-EZ28 to record the wife's soap. When we came home from work the EZ28 had "FROZEN UP" during 6 minutes of the Starting Record Time. According to the time display on the EZ28 the unit had been...
Before replacing anything why don't you try to do a hard reset. If you have the manual it tells you how. If you don't have the manual they have it on the panasonic support site.
Aug 22, 2010 | Panasonic DMR-EZ28K DVD Recorder
WILL NOT DETECT INSERTED DISCS
Lens dirty, have lens clean with DVD lens cleaner.....
Sep 07, 2009 | Panasonic DMR-E85H DVD Recorder
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
Panasonic DMR-EZ28K DVD Recorder Logo
2,028 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
