Question about Vtech CL80109 - - Phone
Is there anyway to deregister a CL80109 handset without the base station. I sold my CL80109 but did not deregister it first, now the new owner says that the handset says "connecting". He needs to deregister it first before it wll allow him to register it to his system, but he does not have the original base unit.
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: how to deregister a handset without the base with which it orginally registered
I successfully reset uniden TCX800 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near LCD.
Posted on Feb 24, 2008
  • 3 Answers
SOURCE: Resetting the Handset
YOU might need to deregister the hand set first by holding down the red end (hang up key) and keep it down while holding the # key. If deregister wont work use base unavailable and yes, you are sure twice.
List the handset numbers of those working handsets
Using a WORKING handset follow these directions
Resetting Handsets
If you want to register the handset to a different base or
replace a handset with another one, you must first clear the
registration information from the base and the handset.
1. Press and hold [ ] and [#] for
at least 5 seconds, until the
SYSTEM RESET menu
appears.
2. Select the DEREGISTER HS
submenu. WHICH HANDSET?
appears in the display.
3. Move the cursor to select the handset ID to be de-registered
from the list, and then press the OK soft key. DEREGISTER HS
appears. CHOSE A NUMBER THAT IS NOT ONE OF YOUR WORKING HANDSETS
4. Move the cursor to select YES, and then press the OK soft key.
When ARE YOU SURE? appears, select YES. You will hear a
confirmation tone.
PUT THE HANDSET IN THE BASE CHARGER AND IT SHOULD REGISTER
Hope This Helps - It worked for me
Posted on Oct 02, 2008
SOURCE: nEED TO DEREGISTER LOST HANDSET
I had this problem too. Hold "End" and "#"at the same time fora few seconds and it will deregister. Then just put it on the new base.
Posted on Aug 19, 2009
SOURCE: Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
Posted on Sep 20, 2009
How do i deregister an orphaned AT&T TL92273 handset?
  • Press and hold handset locator on base station until 'in use' light comes on.
  • Press # on the handset and the phone registers itself to the base station.
I repeated the above procedure with my two remaining handsets and now I have a 6 handset cordless system for my home.
It's important to note that if you have a working base station you should use the standard instructions for deregistering the handsets. Each handset gets allocated a handset number by the base station, if you deregister using the special code detailed in this post then the reserved handset number on the base station is consumed and cannot be reclaimed; thus reducing the number of handsets the base station can support by 1. The special code is only for use when you have a handset that is orphaned from a lost or non-working base station. www.apparelstore38.com
Jul 14, 2017 | AT&T Lands Phones
Deregister AT&T SL82118 handset
The following is for the model ATT 5830.
Enter the following sequence on the base station including the * symbols.
**335782
This will deregister all handsets associated with that base station. Handsets can then be added back into the system by entering the base station ID into the handsets one by one. The base station ID is on the bottom of the base station itself.
Feb 06, 2014 | AT&T 5830 Cordless Phone
Deregister used panasonic handset without base
On another working handset do the following;
Menu #131
Scroll and select the handset you want to deregister
Confirm you want to deregister
"Deregister" screen will display and handset will be deregistered
Feb 15, 2012 | Panasonic KX-TGA650B 5.8GHz 2 Line...
I need to deregister a DS6101 without the base. I needed to replace the base and once we installed the new base, the extra handset that we had registered with our old base shows the following message...
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Feb 16, 2011 | Vtech DS6101 19 GHz Cordless Phone
What does it mean by out of range or no power at base
Maybe you handset was registered to another base at one time or another. The mmessage out of range will show up also if it cant see the base.
If you have a DS6101 you can manually deregister the handset without having the original base it was registered too by doing the following steps:
Hope this helps,
James Pavicic Jr
Nov 16, 2010 | Vtech DECT 6.0 Digital Cordless Phone
Deregister a ds6322-4 without the base
for the Vtech cordless phones model DS6322-4 models
In the handset press
*331734# and the menu button, yur handset will be deregistered.
Enjoy unlocking :-)
May 06, 2010 | Vtech Lands Phones
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Jul 16, 2008 | Uniden TRU8885-2 Cordless Phone
Cannot register handsets
I was having the same problem, and ended up putting each handset in the main base station to register.
Nov 11, 2007 | Uniden TRU8885-2 Cordless Phone
Vtech CL80109 - - Phone Logo
118 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
