Question about Ovens
F 03 message on Bauknecht Cuisine. Thank you alnavarrob@gmail.com
  • alnavarrob Mar 24, 2011
    Have receved no assistance, only advertisements. Need copy of troubleshooting guide to learn how to fix F 03 fault.
Bauknecht oven fault codes f7
A fault in the electronic programmer
May 14, 2018 | Ovens
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
What kw is my leisure cuisine master 100
If this is the RCM10CR model with electric hob and oven than it has a maximum rating of 13.8Kw (Page 6 of the manual, a pdf of which can be found here: http://www.leisurecp.co.uk/upl/31115-RCM10CR.pdf )
If it is the dual fuel RCM10FR then it has a maximum rating of 7.7Kw (page 6 of the manual, a PDF of which can be found here: http://www.leisurecp.co.uk/upl/55403-RCM10FR.pdf )
Jul 28, 2011 | Ovens
How do i reset my bauknecht oven clock?
This is what worked for me:
1) hold down the "Select" button for 5 seconds till the display starts flashing
2) use the right hand dial to set the hour
3) press the "Select" button
4) use the right hand dial to set the minutes
5) press the "Select" button
Mar 20, 2010 | Whirlpool GBS277PDS Electric Single Oven
Bauknecht Mod. BSC 1000 nothing working. Checked fuses - is there a switch/fuse on the oven that could have blown?
THERE IS A THERMAL SWITCH ON THE OVEN INSIDE FOLLOW THE POWER CABLE TO THE CONTROL SWITCH. MOST OVENS HAVE A THERMAL SAFETY INSIDE THEM INCASE THEY GET TO HOT
Mar 08, 2010 | Baumatic B187 Stainless Steel Electric...
I need a manual for a Welbilt Confection Toaster Oven
I have manual for welbilt model cv6311
Jan 31, 2010 | Ovens
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Ovens Logo
161 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
