Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I have a C970 Cooktop - None of the burners work but everything else works. It is coming up with 2 codes E01 and E14 Can you please advise what these codes mean and how to fix this problem
  • 1,998 Answers
Could be the thermostat, glow bar, valve or wiring but usually the glow bar also known as the ignitor if you have any further questions message me back also if you do an ampere test on the ignitor should be drawing in between 3-3.3 amps any less and you would replace the ignitor and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
Posted on Apr 01, 2011
Frigidaire oven and broiler stopped working but clock andtop burners work
Hello Friend, this is Z. I am happy to assist you!
I see that both the clock and burners of your Frigidaire range are working but your oven does not bake or broil. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you!
Sep 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
Maytag mgs5870adb range-gas runs, igniter does not click on any of the 4 burners. all the rest of the oven works
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Ovens
Not heating up right
Hi,when Element does not heat up correctly
1. Test for power to determine that the unit is receiving the correct voltages.
2. If the power voltages are correct and you have standard surface burner elements:
1. Test Surface Burner.
2. Test the Receptacle.
3. Test the Burner Switch.
3. If the power voltages are correct and you have solid-disc elements:
1. Test the solid-disc element.
2. Test the Burner Switch.
4. If the power voltages are correct and you have radiant heating elements:
1. Test the radiant heating element.
1. Make sure the controls are set properly that the oven selector switch is set correctly and that the temperature switch is set to the desired temperature. Where applicable, make sure the oven timer is set to manual.
2. Make sure the oven door is slightly ajar as per your owner's manual.
3. If nothing else on the Range, Oven or Cooktop is working then:
1. Check the circuit breaker or fuse
2. Test for power
4. Test the broiler element.
5. Check the oven thermostat.
6. Check selector switch.
7. Check oven cycling relay.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION .
Please if no experience, please contact a skillful personnel for assistance.
Thanks for using fixya..and please don't forget to rate me 100%.
Thanks.
Oct 28, 2010 | Ovens
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
128 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
