Question about Logitech Z523 2 Speakers
Hi there, ive got logitech speaker system z523, ive had them for around 7 months now haven't had any problems with them, all of a sudden my 2nd speaker just doesn't seem to work, and i've tested them but only sound comes out the right speaker, and everything is connected. What should I do?
    Scholar:
  • 87 Answers
first of all you should try with a different audio source to make sure that the problem resides in your speakers. Then you could try to move the left speaker's cable to see if that is causing the problem and fix it if you have some good soldering skills, otherwise you can just send them back in assistance since they have a 1 year long warranty.
Hope it helped,
Franz
Posted on Mar 24, 2011
Does anyone have a schematic for the Logitech Z523?
Logitech might be able to supply a schematic if you inquire.
Jan 13, 2015 | Audio Players & Recorders
Logitech z-506 computer speakers not working
Have you got the 3.5 mm plug in the sound out it could be in the mic hole.
Aug 29, 2014 | Logitech Z 506 - Pc Multimedia Home...
Logitech speakers suddenly stopped working
try first unplugging the speakers overnight then if they sitill dont work try cleaning off connectors i know this is really basic stuff but sometimes it works
May 21, 2012 | Logitech Z506 Surround Sound Speakers
My Logitech x540s suddenly VERY loud! HELP
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
if this fails to fix the problem you might have to uninstall your soundcard restart your computer then reinstall it
click start control panel administration tools computer management device manager scroll to sounds and video controllers expand right click select uninstall
then restart your computer and reinstall your soundcard
hope this helps
Nov 21, 2011 | Logitech X-540 Computer Speakers
I am not able to connect my logitech speaker system z523 to my 32lk450 tv. It worked fine on my last hd tv, I had it connected with rca white and red cables. Is it compatible with my new tv???
The only way you can connect external speakers to this model is to connect to the TV via the headphone jack this way no matter what you are watching DVD, TV, VCR the audio will pass through. Most TV's now do not have speaker outputs as it saves a little money on production. Good Luck : )
Jul 25, 2011 | LG 32 32LK450 32 in. LCD TV
I don't know how to install my logictech Z523 speakers; they are hooked up but no sound and not installed; computer doesn't recognize them and my fiance threw out the instructions so I don't know how or...
Your "line in" from speakers should be plugged into the green (output) port on the back of your tower or the headphone jack on laptop. You will need to hook the 9 pin connector from the right speaker to the subwoofer. The yellow line from left speaker plugs into port labled "subwoofer" on subwoofer. Plug your power cord from speaker system into an outlet. Turn them on, adjust volume. There is no software for this product.
Mar 24, 2011 | Logitech Audio Players & Recorders
What's the output of the speaker system in watts ?
Hello
Audio power is the electrical power transferred from an audio amplifier to a loudspeaker, measured in watts. The electrical power delivered to the loudspeaker and its sensitivity determines the sound power level generated (with the rest being converted to heat).
Amplifiers are limited in the electrical energy they can amplify, loudspeakers are limited in the electrical energy they can convert to sound energy without distorting the audio signal or destroying themselves. These power ratings are important to consumers finding compatible products and comparing competitors
Do rate, if got help
Dec 04, 2010 | Logitech Z523 2 Speakers
Speakers getting power but not sound
check the speaker.. could be burned or open connection
May 17, 2010 | Logitech Z523 2 Speakers
Logitech Z-680
You need a 2 Amp Slow Blow fuse. 250V. Available from eBay
Aug 01, 2007 | Logitech Z-680 Speakers and DVD218 System
Logitech Z523 2 Speakers Logo
496 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
