Question about Belkin F5L010
Dear Expert I have a been using a blenking f5l010 power adapter for my toshiba laptop. Unfortunately the power tip for toshiba has been broken and would like your advice on fixing the problem. thank you
Toshiba c655d-s5133 plugged in not charging
Dead battery? Try another cord/charger with the EXACT same power specs.
Jan 25, 2013 | Toshiba Satellite Computers & Internet
Plugged in not charging
There could be several things wrong. You could have a broken DC jack on your motherboard. To prove this, wiggle the DC jack with the adapter plugged in. If the charging light comes on when you wiggle the jack, then your jack is broken. You could also have a defective AC adapter.
Jan 06, 2013 | Toshiba Satellite C655-S5125
Toshiba satellite won't go on
Hello. It sounds like either...
1. Your power adapter is damaged/not working. Look and see if a LED is illuminating on the power adapter. If it is chances are it is working fine and the problem may lie on your laptop. If not replace it. The easiest way to tell if your power adapter is bad is to go out to Wal-Mart or your local technology store and purchase one of their universal power adapters. They are expensive but you can buy it, try it, and return it if it does not solve the problem.
If you are going to buy a new toshiba ac adapter, you may consider the following toshiba l355 charger:
Replacement Toshiba Satellite L355 AC Adapter 90Watt 19V 4.74A
OR
2. The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50
Dec 01, 2012 | Toshiba Satellite L355-S7811 Notebook
Toshiba Laptop M 205 hangs, shuts off when connected to AC power pl. help.
Solutions :-
THIS IS BECAUSE OF MOTHERBOARD PROBLEM, U NEED TO REPLACE CAPACITOR PACK WHICH IS AVILABLE BOTTOM OF MBD
thanks...........
find me on google :- LAPNOSYS
Chip Level Motherboard Expert
Apr 08, 2011 | Toshiba Satellite M205-S7453 Laptop AC...
Toshiba satelite computer wont turn on
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 17, 2010 | Toshiba Satellite A105 Notebook
Try to power up my toshiba satellite and the light blinks 8 time and will not power up. can you help me.
5. The power button could be bad.
Sep 12, 2010 | Toshiba Computers & Internet
My toshiba model # psaf3u-0nr00v, No power
Sep 08, 2010 | Toshiba Satellite A205-S5804 Notebook
Computer doesn't completely boot-up. Little history, needed a new ac adapter and bought a 3rd party/universal adapter (from 2 different vendors) and either adapter worked. Did get power to the computer but...
Sep 08, 2010 | Toshiba Satellite M35-S456 Notebook
Laptop won't run on ac power and keeps shutting down
Check that the AC power works, go to a repair shop and test a different one or have voltages checked with a multimeter.
If the AC adapter is fine, then it is usuall because AC socket solder joints on laptop are broken. In this case , it is a delicate repair, and must be done by an expert repairman.
Dec 13, 2008 | Toshiba (K000006610) for Satellite P25...
Ac adapter
My first thought is "yes" as long as it says Toshiba on it, but if you have one that fits, check for the same wattage, and amps. The whole thing could go up in smoke even if the adapter has the right voltage - if the amps supplied by the adapter are too high.
Thanks,
Mark
Aug 18, 2008 | Computers & Internet
Belkin F5L010 Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
